I do not have it. I can connect via usb and then if I switch port to wifi, i get window to enter password, but it is not accepted. And if I try to open serial monitor I also need to enter password, but is not accepted…
Don’t use that feature… it will never work.
You can ONLY use Serial Monitor when connected to USB and have a local COM port selected.
Because it is not for ESP’s. Serial Monitor password requests are for some weird Arduino with WiFi.
I am using Wemos D1 and Wemos D1 mini with code from this topic. It used to work as it should (actually update over wifi is faster than via USB), but for a last few weeks I can not upload over wifi to any of my projects.
I did some library updates in arduino IDE and installed some additional libraries, but this should not effect. Anyway maybe someone could suggest latest library that works for OTA and I should try to install this one.
Downgrade to Arduino IDE 1.6.9.
Trust me… it will fix all your issues! Its the holy-grail version of Arduino IDE(so far)
@monaco you mention passwords but that is not ESP related. Did you actually set a password for OTA?
1.6.12 is working fine for OTA updates.
for me, both OTA and blynk work perfectly individually but not together… It fails during the setup:
- if I setup OTA first and then Blynk, blynk fail to connect to wifi
- if I setup blynk first and then OTA , OTA fail to connect to wifi
any idea ?
edit :SOLVED !!
here is my setup code:
Blynk.begin(auth, ssid2, pass);
Serial.println("Booting");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
@bobli sketch, MCU, Smartphone, local or cloud, IDE version, Blynk library version, Arduino core version, shoe size etc?
how?
I have posted my new setup code, if you initialise blynk first, for the ota part only you only need ArduinoOTA.begin(); and not the rest (you MUST delete the rest of OTA setup)
This indication sould be written in the frst post
Any way to have OTA serial monitor, for remote development ?
edit: here is a dirty workaround, if anybody has a better solution he’s welcome
edit 2 : in fact it doesn’t work
here is my own solution
I have opened another thread about this question here ![]()
Code snippets should be formatted. Please edit your initial post:
How to do that:
``` cpp <--put 3 backticks BEFORE your code starts ("cpp" means C++ language)
//Put your code here
``` <--insert 3 backticks AFTER your code
**This makes your code readable and with highlighted syntax, like this
//comment goes here
void helloWorld() {
String message = "hello" + "world";
Hi, I’d like to ask. How can I embed OTA code to my own sketch for me to be able to upload code over and over again through OTA. I’ve tried many times but always fail.
Here’s my code with embedded OTA (BasicOTA.ino): Any help would be appreciated. Thanks Much.
This is Temperature and Humidity Sensor (DHT22)
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <DHT.h>
// Replace with your network credentials
const char* ssid = "*******";
const char* password = "********";
const char* server = "********"; //server for my database where I store my Data.
#define DHTPIN 4 // what pin we're connected to
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
WiFiClient client;
int redPin = 12; //Red LED, connected to digital pin 12 (D6)
int grnPin = 14; //Green LED, connected to digital pin 14 (D5)
int bluPin = 13; //Blue LED, connected to digital pin 13 (D7)
int sensorPin = 4; //DHT22 Pin, connected to digital pin 4 (D2)
WiFi.mode(WIFI_STA);
dht.begin();
pinMode(redPin, OUTPUT);
pinMode(grnPin, OUTPUT);
pinMode(bluPin, OUTPUT);
WiFi.begin(ssid, password);
Serial.println();
Serial.println();
Serial.println(ssid);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(500);
ESP.restart();
Serial.print(".");
// Port defaults to 8266
// ArduinoOTA.setPort(8266);
// Hostname defaults to esp8266-[ChipID]
// ArduinoOTA.setHostname("myesp8266");
// No authentication by default
// ArduinoOTA.setPassword((const char *)"123");
ArduinoOTA.onStart([]() {
Serial.println("Start");
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("");
ArduinoOTA.handle();
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Serial.print(t);
Serial.print(" ");
Serial.print(h);
Serial.println("% send to Server");
delay(500);
if (client.connect(server, 80)) {
// Create a URL for the request
String url = "/sample.php?temp_c=";
url += (String(t));
url += ("&humidity=");
url += (String(h));
//Serial.print("Requesting URL: ");
//Serial.println(url);
// This will send the request to the server
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + server + "\r\n" +
"Connection: close\r\n\r\n");
client.stop();
if (t >= 27)
digitalWrite(redPin, HIGH);
delay(300000);
digitalWrite(redPin, LOW);
digitalWrite(grnPin, LOW);
digitalWrite(bluPin, LOW);
if ((t <= 27) && (t > 16))
digitalWrite(grnPin, HIGH);
delay(300000);
if (t <= 16)
digitalWrite(bluPin, HIGH);
delay(300000);
//Serial.println("Waiting...");
// delay between updates
//delay(10000); //2 minute delay
@vanjsy it doesn’t work because your hardware is permanently asleep with those crazy delay(300000) entries you have in loop().
With or without Blynk you need SimpleTimer to call functions at intervals.
Hi Sir, thank you. How about this one Sir? Once uploaded via OTA I cant upload another code via OTA. I dont know if i made a mistake embedding the code to my own sketch.
#include <DHT.h>
const char* ssid = "***********";
const char* password = "*******";
cons char* server = "******************";
#define DHTPIN 4
const int sensorPin = 4; //DHT22 Sensor
WiFiClient client;
void setup(){
dht.begin();
//WiFi.begin(ssid,password);
//Serial.println();
//Serial.println();
//Serial.print("Connecting to ");
//Serial.println(ssid);
while(WiFi.waitForConnectResult() != WL_CONNECTED) {
delay(500);
Serial.print(".");
ESP.restart();
ArduinoOTA.begin();
Serial.println("Failed to read from DHT sensor");
}else{
Serial.print(t);
Serial.print("\t");
Serial.print(h);
Serial.print("\t");
delay(500);
if (client.connect(server,80)) {
// We now create a URI for the request
url += (String(t));
url += (String(h));
I’ve been working in days but I can’t solved it.
Please help. Thanks much.
Try it with just the single line of ArduinoOTA.handle() in loop().
If it works, how can i embed my code to send my data into my database? The GET one.
Okay, I’ll post here once working without those code for my database, if I can upload random code again
SimpleTimer but get OTA working first.
Please Visit Advantages and Disadvantages of OTA Upload
and Write your Own experiences about advantage or disadvantage of OTA Uploading
Thank you.
