That is part of the Over The Air update option for ESP (basicly uploding your sketch over the WiFi network instead of plugging it into USB) - see here for example C++ Blynk (Legacy) - Code Examples for Basic Tasks - #2 by Gunner Nothing to do with Timers
Thanks again @Gunner I realize that I don’t need to code this in my case, 'cos I using ethernet shield I’ll try to use this code to my project and see if it’s work for me.
This is my code, but still have issues, please help me!!!
#include <Ethernet.h>
#include <TimeLib.h>
#include <OneWire.h>
#include <WidgetRTC.h>
#define echoPin 3 // Echo Pin
#define trigPin 5 // Trigger Pin
#define ONE_WIRE_BUS 2
BlynkTimer timer; // define a timer for use by SimpleTimer library
WidgetRTC rtc;
int WM1=6;
int EncWV1=6; // Global variable used in Slider widget and runEveryMinute()
int ApagWV1=6; // Global variable used in Slider widget and runEveryMinute()
int WM2=7;
int EncWV2=7; // Global variable used in Slider widget and runEveryMinute()
int ApagWV2=7; // Global variable used in Slider widget and runEveryMinute()
int x, y, z, a;
int CounterOn = 0;
int CounterOff = 0;
int ledStatus = 0;
int CounterOn2 = 0;
int CounterOff2 = 0;
int ledStatus2 = 0;
int AutoRelleno=8;
int SumpLamp=9;
float Celsius = 0;
float Fahrenheit = 0;
char auth[] = "c046b3f28da144598e5119d4d2cfb74d";
long duration, distance; // Duration used to calculate distance
int NivelMax=0;
int NivelMin=0;
char currentTime[9];
char startTime[9];
char stopTime[9];
int SThour;
int STmin;
int STsec;
int SPhour;
int SPmin;
int SPsec;
BLYNK_CONNECTED()
Blynk.syncAll(); // Synchronize hardware with App widgets when connected
Blynk.syncVirtual(V10); // Synchronize Time Input Widget when connected
BLYNK_WRITE(V0)
{ // add a slider to your project on V0 range 0 to 120 (seconds)
x = param.asInt(); // set variable as Slider value
EncWV1 = x;
Serial.print("Wave Maker 1 On Timer set to: ");
Serial.print(EncWV1);
Serial.println(" seconds");
BLYNK_WRITE(V1)
{ // add a slider to your project on V1 range 0 to 120 (seconds)
y = param.asInt(); // set variable as Slider value
ApagWV1 = y;
Serial.print("Wave Maker 1 Off Timer set to: ");
Serial.print(ApagWV1);
BLYNK_WRITE(V2)
z = param.asInt(); // set variable as Slider value
EncWV2 = z;
Serial.print("Wave Maker 2 On Timer set to: ");
Serial.print(EncWV2);
BLYNK_WRITE(V3)
a = param.asInt(); // set variable as Slider value
ApagWV2 = a;
Serial.print("Wave Maker 2 Off Timer set to: ");
Serial.print(ApagWV2);
BLYNK_WRITE(V7)
NivelMax = param.asInt(); // set variable as Slider value
Serial.print("Encender bomba en: ");
Serial.print(NivelMax);
Serial.println(" segundos");
BLYNK_WRITE(V8)
NivelMin = param.asInt(); // set variable as Slider value
Serial.print(NivelMin);
BLYNK_WRITE(V10) { // Called whenver setting Time Input Widget
TimeInputParam t(param);
SThour = t.getStartHour();
STmin = t.getStartMinute();
STsec = t.getStartSecond();
SPhour = t.getStopHour();
SPmin = t.getStopMinute();
SPsec = t.getStopSecond();
void led_control()
//First Wave Maker
if ((CounterOn > 0) && (ledStatus == 0))
digitalWrite(WM1,HIGH); //write to pin to turn the LED on.
Serial.print("Wave Maker 1: ON\n");
ledStatus = 1;
CounterOff = 0;
if ((CounterOn > 0) && (ledStatus == 1))
CounterOn = (CounterOn - 1);
if ((CounterOff == 0) && (CounterOn == 0) && (ledStatus == 1))
CounterOff = ApagWV1;
if ((CounterOff > 0) && (ledStatus == 1))
digitalWrite(WM1,LOW); //write to pin to turn the LED off.
Serial.print("Wave Maker 1: OFF\n");
ledStatus = 0;
CounterOn = 0;
if ((CounterOff > 0) && (ledStatus == 0))
CounterOff = (CounterOff - 1);
if ((CounterOff == 0) && (CounterOn == 0) && (ledStatus == 0))
CounterOn = EncWV1+1;
//Second Wave Maker
if ((CounterOn2 > 0) && (ledStatus2 == 0))
digitalWrite(WM2,HIGH); //write to pin to turn the LED on.
Serial.print("Wave Maker 2: ON\n");
ledStatus2 = 1;
CounterOff2 = 0;
if ((CounterOn2 > 0) && (ledStatus2 == 1))
CounterOn2 = (CounterOn2 - 1);
if ((CounterOff2 == 0) && (CounterOn2 == 0) && (ledStatus2 == 1))
CounterOff2 = ApagWV2;
if ((CounterOff2 > 0) && (ledStatus2 == 1))
digitalWrite(WM2,LOW); //write to pin to turn the LED off.
Serial.print("Wave Maker 2: OFF\n");
ledStatus2 = 0;
CounterOn2 = 0;
if ((CounterOff2 > 0) && (ledStatus2 == 0))
CounterOff2 = (CounterOff2 - 1);
if ((CounterOff2 == 0) && (CounterOn2 == 0) && (ledStatus2 == 0))
CounterOn2 = EncWV2+1;
void MeasureCm()
/* The following trigPin/echoPin cycle is used to determine the
distance of the nearest object by bouncing soundwaves off of it. */
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
//Calculate the distance (in cm) based on the speed of sound.
distance = duration/58.2;
Serial.print("Distance: ");
Serial.println(distance);
Blynk.virtualWrite(4,distance);
if (distance>NivelMax)
digitalWrite(AutoRelleno, HIGH);
WidgetLED AR(5); //means you need to have LED on app configured on virtual pin 1.
AR.on();
Serial.print("Bomba de Autorelleno Encendida");
if (distance<NivelMin)
digitalWrite(AutoRelleno, LOW);
WidgetLED AR(5); //means you need to have LED on app configured on virtual pin 5.
AR.off();
Serial.print("Bomba de Autorelleno Apagada");
void Temperatura()
Celsius = sensors.getTempCByIndex(0);
Blynk.virtualWrite(6,Celsius);
Serial.print("Temperatura: ");
Serial.print(Celsius);
Serial.print(" C");
void EncendidoSumpLamp() { // call with timer every 30 seconds or so
// Get RTC time
sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second());
Serial.print("Current Time: ");
Serial.println(currentTime);
// Get Time Input Widget time
sprintf(startTime, "%02d:%02d:%02d", SThour, STmin, STsec);
Serial.print("Start Time: ");
Serial.println(startTime);
sprintf(startTime, "%02d:%02d:%02d", SPhour, SPmin, SPsec);
Serial.print("Stop Time: ");
if (hour() == SThour) {
if (minute() == STmin) {
Serial.println("Doing something now");
digitalWrite(SumpLamp, HIGH); // Turn ON built-in LED
} else if (minute() < STmin) {
Serial.println("Will do something");
} else if (minute() > STmin) {
Serial.println("Did something");
Serial.println("Clueless");
if (hour() == SPhour) {
if (minute() == SPmin) {
Serial.println("Stopping something now");
digitalWrite(SumpLamp, LOW); // Turn OFF built-in LED
} else if (minute() < SPmin) {
Serial.println("Will stop something");
} else if (minute() > SPmin) {
Serial.println("Stopped something");
Serial.println("----------");
if (EncWV1== 0)
EncWV1=1;
if (ApagWV1== 0)
ApagWV1=1;
sensors.begin();
Blynk.begin(auth);
rtc.begin();
// run timer every 1 second to check for led On/Off action
timer.setInterval(1000L, led_control);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(12, OUTPUT);
timer.setInterval(1000L, MeasureCm);
timer.setInterval(20000L, Temperatura);
timer.setInterval(1000L, EncendidoSumpLamp); // EncendidoSumpLamp Time Check
timer.run(); // Initiates Timer to ensure the timer keeps running
Works fine for a time, then wen the advanced input timmer run out it crash everything and lost conection.
