The Virtual Pins
Link works for me and takes me to https://github.com/blynkkk/blynk-library/blob/master/examples/GettingStarted/GetData/GetData.ino
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * You can use this sketch as a debug tool that prints all incoming values
 * sent by a widget connected to a Virtual Pin 1 in the Blynk App.
 * App dashboard setup:
 *   Slider widget (0...100) on V1
#include <Ethernet.h>
  Blynk.begin(auth);
// This function will be called every time
// when App writes value to Virtual Pin 1
BLYNK_WRITE(V1)
  BLYNK_LOG("Got a value: %s", param.asStr());
  // You can also use:
  // int i = param.asInt() or
  // double d = param.asDouble()
June 2016, link still broken.
@pete_l if you are using the Arduino IDE you don’t need a link as it is included as one of the Blynk examples.
June 13th 2016, link still working here.
@pete_l, http://docs.blynk.cc/#blynk-main-operations-virtual-pins ?
