In theory yes, but in practice no.
You are mixing 2 terms.
Blynk Project - interface made in Blynk app
Exported app (e.g myPlant) - which is a project made with Blynk and then exported into a standalone app and published to app stores under your name āAgupte Smart Lockā app
Blynk project can b shared with other people by scanning QR code. Owner of the project can refresh the code, so all the people will loose the access.
Exported app works differently. There are no roles supported yet.
@Dmitriy Iāve been waiting for the bugs to be ironed out before moving to the multi device version of the app and library. Hopefully Iāll upgrade in the next week or so.
@Dmitriy I wasnāt aware this was ready yet, but trying to work with it, I see I need my local server updated by you at your convenience. If it works good I will be upgrading my account.
Cloud, moving to the larger business subscription with this update though. Was just using regular blynk app with their dedicated server waiting for this
@Dimitry , I tried it on 2 D1 minis so far so good, no lags or bugs are detected, In a couple of days later I will try it on all my ESPs with physical button interrupt code for my home switches. So this feature, I have been waiting for a long time, awesome job
Dear Dmitriy,
the multi device BLYNK feature is very attractive and I will test it when my time permits so. These days I have lot to do for my work so it will take a couple of weeks to test it and I let you know!
Hi @Dmitriy,
Iām just doing a small project with two ESPās (ESP8266-1 and ESP8266-2) and I wanted to show data at āHistory Graphā for both devices at the same time and the widget doesnāt allow thisā¦ I must choose ESP8266-1 or ESP8266-2
You can find same issue with the āNotification widgetā and the āReal-time clockā, if I use those widgets for the first device I canāt use them for the secondā¦
@psoro Thanks. Correct. History graph need to be refactored in order to support multi devices. Notifications - will work for every device. And RTC need to be refactored too. We will fix this over a time.
Thanks @Dmitriy,
One more thing, It should be fine if the App shows the name of the device when is offline, not only āone of your devices is offlineā. At the moment I have only two at the same dashboard but I can imagine myself looking for the one offline through my houseā¦
