it means how strong your wifi is. -65dB is about the minimum for a decent wifi connection. -70dB is a lousy connection and everything above -60dB is considered good enough for streaming applications like VOIP and video
thanks
Sorry. Perhaps I took the word ācloneā too literally. Obviously, more sophisticated switching devices are useful variants of the Sonoff, but donāt fall under a strict definition of the word clone.
On a side note, the Blynk discussion forum is usually a pretty friendly place. We can always disagree without resorting to insult.
woah ragey mc rager over hereā¦
Best wishes to you and your future.
Iām retired.
Haha lucky for some!
Hello there. What part of sketch do I need to change to make it work with normally open connection? Meaning SWITCH_PIN LOW instead of HIGH and vice versa? I tried to do that with no luck
BR
Hey Zbx!
Sorry its taken so long to reply.
You just need to invert the bits on the following lines:
^^ Change 1 to 0
^^ Change 0 to 1
Inverted!
in code where i put ssid and pass ssid? and which ouput pins are selected in the blynk app? I do not run for a local serverā¦thx
All in settings.h
HI
here is part of my sketch for a (+ve) activated Relay
* switch.h
int SwitchState, timer1, SwitchDelay;
WidgetBridge gate(vPIN_BRIDGE_GATE);
BLYNK_CONNECTED() {
gate.setAuthToken("xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx");
void Switch_OFF() {
digitalWrite(RELAY_PIN, 0);
Blynk.virtualWrite(vPIN_BUTTON_MANUAL, 0);
Blynk.virtualWrite(vPIN_LED, 0);
void Switch_ON() {
digitalWrite(RELAY_PIN, 1);
Blynk.virtualWrite(vPIN_BUTTON_MANUAL, 1);
Blynk.virtualWrite(vPIN_LED, 255);
void Switch_Toggle(bool state) {
digitalWrite(RELAY_PIN, state);
SwitchState = digitalRead(RELAY_PIN);
if (SwitchState) { SwitchState = 255;
Blynk.virtualWrite(vPIN_LED, SwitchState);
}else{ SwitchState = 0;
BLYNK_WRITE(vPIN_BUTTON_TIMEOUT) { // remote delay Switch
if ((digitalRead(RELAY_PIN))== 0)
Switch_ON();
timer.setTimeout(SwitchDelay, Switch_OFF);
BLYNK_WRITE(vPIN_BUTTON_MANUAL) { // manual button
Switch_Toggle(param.asInt());
BLYNK_WRITE(vPIN_TIMER) { // timer Switch
if (param.asInt()) {
Switch_ON();
gate.virtualWrite(vPIN_BRIDGE_GATE, param.asInt());
Switch_OFF();
BLYNK_WRITE(vPIN_SLIDER_TIMEOUT) {
SwitchDelay = param[0].asInt() * 60000;
Blynk.syncVirtual(vPIN_BUTTON_TIMEOUT);
My Smart Plug
Thanks to Jamin
May I ask what you used as a power supply for the esp
Thanks. Love the title, dangerous
Looks cool!
Whatās the BOM?
