Sure thing:
// included library code:
#include <LiquidCrystal.h>
#include <IRremote.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(43, 42, 41, 40, 39, 38);
char auth[] = "2e12807d32d441b0a24ccce76b224e08";
// Initialze IR Receive (Not functioning as of 1/7/2016)
int RECV_PIN = 34;
IRrecv irrecv(RECV_PIN);
decode_results results;
// temperature sensor goodies
const int sensorPin = A14;
const int sensorPin2 = A15;
const float baselineTemp = 18.0;
// Relays that are used to control the power to all the network devices
#define RELAY1 22 // 1 on Sainsmart Powers Outlet 1 on HTS3600
#define RELAY2 23 // 2 on Sainsmart Powers Outlet 2 on HTS3600
#define RELAY3 24 // 6 on Sainsmart Powers Outlet 3 on HTS3600
#define RELAY4 25 // 7 on Sainsmart Powers Outlet 4 on HTS3600
#define RELAY5 26 // 8 on Sainsmart Powers Outlet 5 on HTS3600
// Relay Output Pin for Cooling Fan Control to 12V Source
#define RELAY9 27 // 9 on Sainsmart Cabinet Cooling Fan
#define RELAY10 28 // 10 on Sainsmart Power Unit Cooling Fan
// There must be one global SimpleTimer object.
//Blynk Serial Print
// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V2);
void BCRead() {
//what we want to run every 10 milli-seconds here:
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
terminal.print(results.value, HEX);
irrecv.resume(); // Receive the next value
delay(100);
if (results.value == 0xE0E036C9) { // Red Button
digitalWrite(27, LOW);
delay(100);
if (results.value == 0xE0E028D7) { // Green Button
digitalWrite(27, HIGH);
delay(100);
if (results.value == 0xE0E0A857) { // Yellow Button
digitalWrite(28, LOW);
delay(100);
if (results.value == 0xE0E06897) { // Blue Button
digitalWrite(28, HIGH);
delay(100);
if (results.value == 0xE0E0629D) { // Stop Button
Serial.println("Stop Button");
delay(100);
delay(100);
// End of BCRead timed task
void FanLCDTask() {
//Our main temperature and LCD controls running every 10 seconds here:
// read sensor value for 2xTMP36
int sensorVal = analogRead(sensorPin);
int sensorVal2 = analogRead(sensorPin2);
// set the cursor to column 0, line 1
lcd.setCursor(0, 0);
//convert the ADC rating to voltage
float voltage = (sensorVal / 1024.0) * 5;
float voltage2 = (sensorVal2 / 1024.0) * 5;
// convert the voltage to temperature in degrees C
float temperatureC = (voltage - .5) * 100;
float temperatureC2 = (voltage2 - .5) * 100;
// convert to Farenheit
float temperatureF = (temperatureC * 9.0 / 5) + 32.0;
float temperatureF2 = (temperatureC2 * 9.0 / 5) + 32.0;
//display Temperature on LCD
lcd.print(temperatureF);
lcd.print((char)223);
lcd.print("F ");
Blynk.virtualWrite(0, temperatureF);
Blynk.virtualWrite(1, temperatureF2);
delay(100); // (time to settle)
// Cabinet Fan control
if (temperatureF > 75)
lcd.setCursor (8, 0);
lcd.print ("COOLING");
lcd.print ("NORMAL ");
lcd.setCursor(0, 1);
lcd.print (temperatureF2);
lcd.print("F ");
lcd.setCursor(8, 1);
// print the days since reset:
lcd.print("UP");
lcd.print(millis() * 0.0000000115741);
// case cooling fan control
if (temperatureF2 > 75)
// End of FanLCD Actions
// timed actions setup
timer.setInterval(900, BCRead);
timer.setInterval(10000, FanLCDTask);
// timer.setInterval (1000, ModeHandler); // Planning to use this for mode handling thread
// relay pin definitions
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT);
pinMode(RELAY4, OUTPUT);
pinMode(RELAY5, OUTPUT);
pinMode(RELAY9, OUTPUT);
pinMode(RELAY10, OUTPUT);
// these relays go on with "LOW" setting HIGH to start
digitalWrite(RELAY1, HIGH);
digitalWrite(RELAY2, HIGH);
digitalWrite(RELAY3, HIGH);
digitalWrite(RELAY4, HIGH);
digitalWrite(RELAY5, HIGH);
digitalWrite(RELAY9, HIGH);
digitalWrite(RELAY10, HIGH);
// Start Serial for Console Logging (When connected Temperature Results are NOT reliable)
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Managing "Modes" For Xbox, etc.
BLYNK_WRITE(3)
int i = param.asInt();
if (i == 1)
digitalWrite(RELAY2, LOW);
digitalWrite(RELAY1, LOW);
// Blynk Login
Blynk.begin(auth); // Here your Arduino connects to the Blynk Cloud.
// Wait until connected
// This will print Blynk Software version to the Terminal Widget when
// will log messages here, test code functional
terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
terminal.println("-------------");
terminal.println("Type 'Marco' and get a reply, or type");
terminal.println("anything else and get it printed back.");
terminal.flush();
Thanks for looking at this!
