Currently I am trying to set up a project where two switches are acting as as an exclusive or to two lights (only 1 light can be on at a time), however, I am running into trouble accessing the information from the first virtual pin (associated with the first switch). Below, i have included the code, however I have not found a clear example that has allowed me to access the virtual pin.
I have included my current code below
#include <Bridge.h>
#include <BlynkSimpleYun.h>
char auth[] = "*************************";
pinMode(8, OUTPUT);
Blynk.begin(auth);
BLYNK_WRITE(V1){
int pinData = param.asInt();
if (pinData = 1) {
digitalWrite(8, HIGH);
digitalWrite(8, LOW);
void loop(){
edit: I found the mistake, i forgot to close the BLYNK_WRITE function
