this project was working at first with arduino and bluetooth, then I changed it for a esp, and blynk. and it was running without any problemsâŚ
Is that latest app version? When this start happen? did you updated recently or something?
yes, it is latest app version , and this bug has 2 years ago, I did not put it any importance, because I had some prototyping projects running, to control lights, door sensors, with very simple data to show.
It is was fixed recently. And we canât reproduce it. Please try to remove and add widget again. Maybe it will help?
Hello there, i am using the esp 8266 and working great but i have a problem : when the internet wifi signal is lost for seconds my indicators led widget will also get lost .how can i refresh these virtual pins every 5 minutes any help please
any solution ??
Investigating.
Also I have problem of double prints on Terminal widget.
If it helpsâŚ
in my case I found that double prints occur when I launch Blynk App. If then I close the App and launch it again, terminal will print normally (one print).
If I repeat launching/closing the App - normally print.
If I relaunch the App after some time or after I clear RAM on my phone - double prints.
I am using latest library & LG L90
Hi, this weekendâs App update solved unwanted duplicate strings in my case.
Thank you!
thanks, guys. I am really happy to ear that. terminal widget is vital to make a lot of projects.because all data must to be Trustworthy.
Iâm closing this thread for now. We did the possible fix. However it could be not the last fix. So if you see it again please create new topic.
