Itās always possible to forward ports to different other ports. Even on the local lan you can work around this, but itāll be very messy. You can translate virtual ipās in to different other IPās and so on, but Iām shuddering al ready at the thought of how to make that work.
@Lichtsignaal - All I was trying to do is stream two ip cameras within Blynk via WAN. I donāt think itās possible at the moment. LAN is fine you can as many as you want. From what I can see blynk will only stream inbound on port 554 on the WAN side then port 554 on the Lan. You should be able to stream in bound on what ever port you want (ensuring youāve opened that port) from the WAN side as Long as you redirect the streaming path to what ever the port you have set in your ip cameraā¦as default itās usually 554 for rstp.
All sortedā¦simple solution only thought now and it worksā¦as I have an nvr with all my ip cameras connected to Iām now streaming the nvr on port 554 on the WAN side and now I have access to all my cameras within Blynk. Awesome. Thanks everyone for you help and suggestions.
For reference Iām pretty sure the ports are nothing to do with Blynk i.e. you make a direct connection to the url:port from your Smartphone.
If you look online there are many others that have asked about access to multiple cameras via the WAN. Personally I prefer separate tabs with different cameras on each.
Iād like the ability to change the stream URL from the hardwareā¦ then you could have a bunch of streams saved on your hardware and it could cycle through them via timer or on select
@jamin I was planning to use the Menu widget to send the selected url to the Terminal widget. From there I would copy and paste to the Video widget but it doesnāt look like you can cut from the Terminal widget.
No it doesnt cycle through. As far as I can see thereās some kind of restriction with blynk on the WAN side. You should be able to stream from WAN on any port you want then redirect it to the streaming port as per set in your device. I do with other apps no problems. But anyway I have worked around it and can access each camera on different tabs.
