[SOLVED] RGB LED Flasher using blynk via Wifi
Someone please help me. I have to submit it by tomorrow and facing an error!
    #include <ESP8266_SoftSer.h>
    #include <BlynkSimpleShieldEsp8266_SoftSer.h>
    #include <Blynk/BlynkApi.h>
    #include <BlynkApiArduino.h>
    // Set ESP8266 Serial object
    ESP8266 wifi(EspSerial);
    char auth[] = "a20b235cfa794f07981d050950fb4429";
    #define red 11
    #define green 10
    #define blue 9
      // Set console baud rate
      // Set ESP8266 baud rate
      // 9600 is recommended for Software Serial
      EspSerial.begin(9600);
      Blynk.begin(auth, wifi, "username", "password");  // wifi username and password
    BLYNK_WRITE(V1)
      int x = param[0].asInt();
        while(x==1)
        x = param.asInt();
        int i=0,j=0,k=0;
        analogWrite(red, 255);
        analogWrite(green, 255);
        analogWrite(blue, 255);
          for(int j=0;j<20;j++)
           analogWrite(red, 0);
           delay(100);
           analogWrite(green, 0);
           delay(100);
           analogWrite(blue, 0);
           delay(100);
            x = param.asInt();
            if(x==0)
            break;
        for(int z=0;z<10;z++)
        for(i=0;i<=180;i++)
                analogWrite(red, 180-i);
                delay(2);
        for(j=0;j<255;j++)
                analogWrite(green, 255-j);
                 delay(2);
        for(k=0;k<255;k++)
                analogWrite(blue, 255-k);
                 delay(2);
         x = param.asInt();
         if(x==0)
         break;
            for(int z=0;z<5;z++)
        for(j=0;j<255;j++)
                 delay(20);
        for(k=0;k<255;k++)
                 delay(20);
            for(i=0;i<=180;i++)
                delay(20);
        analogWrite(red,180);
         x = param.asInt();
         if(x==0)
         break;
       if(x==0)
       break;
Error that I am facing is: In file included from C:\Program Files (x86)\Arduino\libraries\BlynkSimpleShieldEsp8266_SoftSer/BlynkSimpleShieldEsp8266_SoftSer.h:20:0,
from sketch_feb14a.ino:3:
C:\Program Files (x86)\Arduino\libraries\BlynkApiArduino/BlynkApiArduino.h:14:28: fatal error: Blynk/BlynkApi.h: No such file or directory
compilation terminated.
Error compiling.
Where did you get the sketch, what hardware are you using and why did you leave it so late to do your course work?
Arduino UNO
Esp8266-21
RGB LED
Blynk App
It’s supposed to be, “if you wait until the last minute it only takes a minute.” Maybe not always!
I didn’t get the solution yet!
Please can anyone help me!
What should I use instead of these please help me out. I am unable to find any solution. I will be very thankful to you!
All you need to do is look :wink:
Start with the >Sketch Builder< Also prominently shown at the top right of this page.
Pick your hardware, start at the top and work your way through the much more current examples.
