Hello Blynkers!
I’m starting with Raspberry Pi this week and after think about it I was going to start to blynk with Javascript to make projects with the app, so I start to do this tutorial: Blynk + JavaScript in 20 Minutes [Raspberry Pi, Edison, Espruino …] and first I checked if I have installed the NodeJs with:
node --version
And I saw that I have this version preinstalled on Raspbian with Jessie:
v0.10.29
Then I proceeded with the steps, when I type:
curl -sL "https://deb.nodesource.com/setup_6.x" | sudo -E bash -
The systems responds with:
## Installing the NodeSource Node.js v6.x repo... ## You appear to be running on ARMv6 hardware. Unfortunately ly supported by the NodeSource Linux distributions. Please us' binary tarballs available directly from nodejs.org for Node
But the problem comes when I type the npm commands to install like:
sudo npm install -g npm sudo npm install -g onoff sudo npm install -g blynk-library
The system gave me this message:
pi@raspberrypi:~ $ sudo npm install -g npm
sudo: npm: command not found
I don’t know why I have this problem, I think that I have to install it manually by other terminal command, I hope that somebody could help me to install and make this thing work.
Best regards
