Good evening everyone.
I am completing the sketch that makes me the house home automation. (I’ll publish it soon will be fully working).
Unfortunately I noticed a limitazine use of WidgetLed. Reached 10 WidgetLed, successive no longer work. Unfortunately I was not aware of this limit, and I had to stop.
anyone is aware of this limitation.
There is no listed limit of LED widgets (or any others, short of projects space and energy). I have recently experimented with a dot matrix of 20 widget LEDS… and they all work, most of the time, but if I changed numbers (displayed on the matrix) too quickly, then sometimes only part of the widget LEDs “lit” up. No error msg or disconnect, but still caused by too much data flow causing some widget LED commands to be ignored.
I forgot about that… SimpleTimer has the limit of 10 instances per timer. Making @macignolo issues more timer related than too much data as was in my case.
