I am new to arduino/blynk programming but have manged to put this together so far and everything works except for void phchecker(). Can someone please point me in the right direction?
It worked before but after doing my best to clean up my code I ended up with this and now the only relay activated or table message I have gotten to print from the if/else portion was PhUp activating and indicating pin V5 was being read as less <5.21 rather than the 7.01 that was displaying via a labeled display on pin v5 on my app
Live ph readout via pin V5 to the app works great though.
#include <TimeLib.h>
#define SensorPin 7 //pH meter Analog output to Arduino Analog Input 7
unsigned long int avgValue; //Store the average value of the sensor feedback
float b;
int buf[10], temp;
//pins to pumps
int PhDown = 40;
int PhUp = 42;
//temp Ph Min/Max range and value readout
float PhLow = 5.21;
float PhHigh = 6.23;
char auth[] = "removed";
digitalWrite(PhDown, HIGH);
digitalWrite(PhUp, HIGH);
Blynk.begin(Serial, auth);
pinMode(PhDown, OUTPUT);
pinMode(PhUp, OUTPUT);
timer.setInterval(900000L, phchecker);
timer.setInterval(1000L, PhProbe);
void PhProbe()
avgValue = 0;
for (int i = 2; i < 8; i++) //take the average value of 6 center sample
avgValue += buf[i];
float phValue = (float)avgValue * 5.0 / 1024 / 6; //convert the analog into millivolt
phValue = 3.5 * phValue; //convert the millivolt into pH value
Blynk.virtualWrite(V5, phValue);
void phchecker() {
if (V5 >= PhLow && V5 <= PhHigh)
//placeholder for table message
else if (V5 > PhHigh)
digitalWrite(PhDown, LOW);
delay(3000);
else if (V5 < PhLow)
digitalWrite(PhUp, LOW);
delay(3000);
for (int i = 0; i < 10; i++) //Get 10 sample value from the sensor for smooth the value
buf[i] = analogRead(SensorPin);
for (int i = 0; i < 9; i++) //sort the analog from small to large
for (int j = i + 1; j < 10; j++)
if (buf[i] > buf[j])
temp = buf[i];
buf[i] = buf[j];
buf[j] = temp;
Count your brackets and here is one without function
I see that you comprehend the use of SimpleTimer so in order for you to properly use it you must remove your delays. They halt your entire device.
Instead define a function that sets your pin high and use
Use a global variable to track what pin to set high
int handlePin;
Then in your pH checker
handlePin = PhLow; // or PhHigh depending on if
timer.setTimeout(3000L, someFunction);
void someFunction()
digitalWrite(handlePin, HIGH);
Instead of Delay, this will call the function once after 3s without blocking your code.
Thank you for the advice. I removed the rouge brackets and will work on restructuring the rest today.
I have changed things up to this but it still doesn’t seem to read V5 properly as it activates pin 42 which would mean it is seeing the value as < 5.21 when V5 is currently reading 7.25+ in my app so it should activate pin 40.
For reference my relay is LOW = on HIGH = off . Even though the wrong relay is activating right now due to the above it will not revert after the timeout. Do I need to have it set HIGH when it timesout somehow?
#define SensorPin 7 //pH meter Analog output to Arduino Analog Input 0
float b;
int buf[10], temp;
//pins to pumps
int PhDown = 40;
int PhUp = 42;
int CurrentPump;
float PhLow = 5.21;
timer.setInterval(5000L, PhChecker);
void PhProbe() {
avgValue = 0;
avgValue += buf[i];
void PumpActivate() {
digitalWrite(CurrentPump, LOW);
void PhChecker() {
//placeholder table msg
CurrentPump = PhDown;
timer.setTimeout(3000L, PumpActivate);
CurrentPump = PhUp;
temp = buf[i];
buf[i] = buf[j];
buf[j] = temp;
Ok I’ve finished tonight with this but it still doesn’t seem to properly read pin v5 in the if/else if’s. Always reverts to “else if (V5 < PhLow)” and prints “PhUp Activated” although the labelled display in the app reads it fine.
WidgetLCD lcd(V10);
float b;
int buf[10], temp;
//pins to pumps
int PhDown = 40;
int PhUp = 42;
//Holds PhDown or PhUp Depending on if/else if
int CurrentPump;
float PhLow = 5.20;
float PhHigh = 6.00;
//Auth Code for Blynk App Local Server
//timer
digitalWrite(PhDown, HIGH); //sets pins to high at default. High is off.
timer.setInterval(5000L, PhChecker); //Needs to be changed after testing
timer.setInterval(100L, Probe);
lcd.clear();
void Probe() {
temp = buf[i];
buf[i] = buf[j];
buf[j] = temp;
void PhProbe() {
avgValue = 0;
avgValue += buf[i];
Blynk.virtualWrite(V5, phValue); //writes float to Virtual pin 5 for Blynk App
void PumpActivate()
digitalWrite(CurrentPump, LOW); //Turns on Pump
timer.setTimeout(3000L, PumpDeactivate); //Turns off pump after 3 seconds
void PumpDeactivate()
digitalWrite(CurrentPump, HIGH); //Turns off Pump
void PhChecker() {
lcd.clear();
lcd.print(0, 0, "Ph is good");
CurrentPump = PhDown; //Set CurrentPump to PhDown
PumpActivate(); //Runs PumpActivate
lcd.clear();
lcd.print(0, 0, "PhDown Activated");
CurrentPump = PhUp; //Set CurrentPump to PhUp
lcd.clear();
lcd.print(0, 1, "PhUp Activated");
OH I totally missed this part. Your error is here, you can not use virtual pin reference to get your “app” value
every virtual pin is a variable in itself in this manner
V0 = 0
V1 = 1
V2 = 2
and so forth.
what you need to do is define a function that handles changes on APP side of a widget, on your hardware.
Also if I remember correctly, widgets only work with integers so you need to multiply your widget min max
with an appropriate number 10/100/1000 that allows you to get the resolution you want.
Then divide it when your hardware fetches that number
float someValue = 0; // global variable for assigning your widget value
//When ever you change value in your widget, this function gets called by Blynk library
BLYNK_WRITE(V5)
someValue = param.asFloat() / 1000; // param contains your widgets value sent to hardware.
then do like this
void PhChecker() {
if (someValue>= PhLow && someValue<= PhHigh)
lcd.clear();
else if (someValue> PhHigh)
lcd.clear();
else if (someValue< PhLow)
lcd.clear();
I managed to get it all working. I simply added CurrentPh = phValue; in addition to writing to V5 and added float CurrentPh; as a global then changed my if/else ifs to pull from CurrentPh. I also changed my timing on the probe from reading every 100ms to 1000ms to help prevent flooding.
Everything is working great now. I am still working on learning more and making this as clean as possible but that will come in time. Just glad to have it functioning. All your help was very much appreciated!
float CurrentPh;
void PhProbe() {
avgValue = 0;
avgValue += buf[i];
void PhChecker() {
if (CurrentPh >= PhLow && CurrentPh <= PhHigh)
lcd.clear();
else if (CurrentPh > PhHigh)
lcd.clear();
else if (CurrentPh < PhLow)
lcd.clear();
Super, I’m glad it worked out for you
