If you are using the standard soft serial Blynk sketch, which you should be for an Uno then the baud rate is shown as 9600. It is not recommended to go any higher than this with soft serial and therefore if you are still able to issue AT commands to the ESP you need AT+UART_DEF=9600,8,1,0,0.
If later you move to hard serial which I believe you can do but without Serial Monitor access then you would send AT+UART_DEF=115200,8,1,0,0 as the hard serial sketch has a baud of 115200.
I did the software serial setting baudrate to 9600
With the testing script of @Rom3oDelta7 it got connected to my AP.
Now after uploading softser in uno, in serial monitor it shows failed to disable Echo.
In my tethered network I can see esp has connected to my AP.
But in blynk when I run the project it says your arduino uno is not in network.
If you can’t get overcome the echo issue you will not be in the Blynk network.
One suggestion I have seen (in this thread) and it appears to work in some cases is powering the Arduino before the ESP. I believe this is because the ESP has to be reset when the sketch starts. Some people have capacitors in their circuits which has the same effect.
Are you still powering the ESP from the Uno? The power from the Uno is enough to flash the ESP but not nearly enough to run the ESP. Either way try feeding power to the ESP, from wherever, a a split second before you start the hard serial sketch and see if that breaks through the echo block. You might need 3 hands to do this.
Em still feeding it on uno, but have a 10uf capacitor between vcc and gnd.
If em uploading the hardser sketch I see that there is a term serial1, I guess I have to change it to just Serial.
Secondly where should the esp’s Rx and Tx pin go for this sketch.?
For now I would forget hard serial with an Uno you need soft serial. You can only use Hard Serial with single serial devices (Uno, Nano etc) if you set up a soft serial port to debug your sketch in serial monitor. I don’t recommend this until you have mastered soft serial.
Well all I see is Failed to disable Echo in Soft Serial
Looks like standalone is the only left option for me.
Anyway let’s see what I can do with wemos d1. Guess it’ll Atleast take a month for delivery.
It can be as quick as 2 weeks from China to Europe for the WeMos. My last order has taken about 26 days and they still have about 70km to travel but the order sat for 12 days in China due to the backlog after Chinese New Year.
Maybe come back to Uno with ESP at a later date. It does work and your ESP is fine. It’s not a particularly good way to use the ESP and you can familiarise yourself with Blynk in standalone mode, with the limited ports available in this mode.
ESP’s work better as ESP’s rather than as shields.
If you look in the SmartConfig sketch you will notice there is no SSID and pwd. It basically allows you to connect to SSID’s stored inside the ESP having perhaps previously used one of the AT script commands such as AT+CWJAP=“ssid”,“password”
So smartconfig is better than just standalone ryt.
As to change the ssid or password in the sketch later on would take a little time to set esp up with flashing setup.
We can change the ssid and password by just connecting it with uno And running the AT command ryt. Hope I got that correct
Nearly right, there is no Uno. You send AT commands directly to the ESP and yes if you move from place to place you need to change the SSID and pwd in the standalone sketch for it to work. This would not always be practical but as long as you have a way of sending AT commands to the ESP you can get connected.
The REALLY smart way is provided by one of the Blynk community members @tzapulica
If you look at his github for WiFi Manager at https://github.com/tzapu/WiFiManager you will see it allows you to change the SSID and pwd (plus other stuff) from any web browser when you boot up the ESP. We use it in one of our main sketches which then connects to Blynk wherever we are as long as there is WiFi. Or in your case maybe wherever their is a GSM network to tether the ESP to.
hey sir,
i really need your help, you will save my project, i am facing same problem of Failed to disable echo. how you solved it. my esp8266 version is AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
Ai-Thinker Technology Co. Ltd.
Jun 13 2016 11:29:20
installing AT ver. 0.22 and SDK Ver 1.0 will work?
how you flashed 0.22 version in your ESP8266.
please help me sir, next week i have to submit my last year project. please please please
