[Solved] Failed to disable echo{1619} January 2017
#include <ESP8266_Lib.h>
char auth[] = "auth";
char ssid[] = "Dreamerz";
char pass[] = "pass";
#define EspSerial Serial
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
  // Set console baud rate
  // Set ESP8266 baud rate
plz help error.
AT+C[19]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.4.4 on Arduino Uno
[603] Connecting to Dreamerz
ATE0
[1613] Failed to disable Echo
AT+CIPCLOSE=1
AT+CIPCLOSE=1
AT+CIPSTART=1,"TCP","blynk-cloud.com",8442
[UPD: “Failed to disable echo” will most probably be reported as “ESP is not responding” now]
Do you have USB 2 TTL adaptor wired up to your Uno?
Your problem was covered 7 posts before yours, see [SOLVED] ESP8266 as a wifi shield of Arduino Uno to control a 6 channel Relay
no but i can use my arduino uno and remove its atmega 328p and flash the same code on my nano.
Same problem with the Nano, just one Serial port.
Look through the link I provided.
what i am trying to say is that i can use my uno as a serial converter ttl and monitor the same code flashed on my nano
Yes I believe Arduino’s can be used as USB 2 TTL adaptors.
Let us know how it goes.
okay
i have managed to load the code onto a arduino nano and use arduino uno(without the atmega 328p-pu) as usb ttl converter and it works!!!
[19]
    ___  __          __
        /___/ v0.4.4 on Arduino Nano
[604] Connecting to Dreamerz
ATE0
AT+GMR
[3721] 0018000902
AT+CIPMUX=1
AT+CWMODE?
AT+CWMODE=1
AT+CWJAP="Dreamerz","9988080803"
AT+CIFSR
[9127] 192.168.1.9
[9128] Connected to WiFi
AT+CIPCLOSE=1
AT+CIPCLOSE=1
AT+CIPSEND=1,37
That is excellent news @Sai_Khurana
Presumably you are using 2 USB ports, one for the Arduino Nano as MCU and one for the Uno as a USB 2 TTL adaptor, correct?
For others I have detailed 3 ways to use Arduino’s as USB 2 TTL adaptors
  1. If the chip can be removed take it out
    or
  2. Wire reset and GND together
    or
  3. Flash this sketch
void setup(){
  pinMode(0,INPUT);
  pinMode(1,INPUT);
void loop(){
Credit https://oscarliang.com/use-arduino-as-usb-serial-adapter-converter/
yeah sort off.
actually my arduino nano’s ch340 chip was brokrn when i bought it. so i de-soldered it and used a usbasp to program it.
I have the same problem… Can somebody help??
"failed to disable echo "
Please stick to one post and/or thread.
Sorry :see_no_evil:
