[Solved] Can't buy energy on iOS device
I am trying to purchase 13000 energy points but it does not work.
-iOS app is up todate
-local server is server-0.22.3.jar
-when I tap “buy” the payment process works but the dancing dots just dance forever and no new energy points appear
-when I try again it says the energy has already been purchased and that it will reinstate it at no charge, but still the dancing dots just dance forever and no new energy points appear
Help:confounded:
You don’t need to buy energy if you have a local server…
Go to the admin page on your server https://ip-of-server:7443/admin and you can add your own energy there :slight_smile:
-edit
If you correctly configured your server.properties that is …
Thanks, I will give it a try.
I can’t find any reference to energy tokens in Admin UI. Can you point me to some information on setting up the server.properties correctly?
If you click on Users (left) and then on your username, there is a field “Energy” (right) where you can modify your amount of energy. If you can access the admin page, server.properties is fine.
I do not show a field named “energy”
I have;
“Name”, “App Name”, # of Projects", “Last ModifiesTs”
I found it. I had to select and click on the user name.
Thanks for your help
