[SOLVED] Can not Start Local Server on Win8.1
i have given acess to all the app in google account settings.but i have not received auth tokens i have configured the mail.properties file as below:
mail.smtp.auth=true
mail.smtp.starttls.enable=true
mail.smtp.host=smtp.gmail.com
mail.smtp.port=587
mail.smtp.username=gmail id
mail.smtp.password=gmailpassword
my log file looks like this:
02:51:22.892 ERROR - Error sending email from application. For user ushivasiddharth@gmail.com.
javax.mail.MessagingException: Could not convert socket to TLS;
nested exception is:
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at com.sun.mail.smtp.SMTPTransport.startTLS(SMTPTransport.java:2046)
at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:711)
at javax.mail.Service.connect(Service.java:388)
at javax.mail.Service.connect(Service.java:246)
at javax.mail.Service.connect(Service.java:195)
at javax.mail.Transport.send0(Transport.java:254)
at javax.mail.Transport.send(Transport.java:124)
at cc.blynk.server.notifications.mail.MailWrapper.send(MailWrapper.java:60)
at cc.blynk.server.notifications.mail.MailWrapper.send(MailWrapper.java:46)
at cc.blynk.server.application.handlers.main.logic.AppMailLogic.lambda$mail$0(AppMailLogic.java:65)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1949)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1509)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:979)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:914)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1062)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1403)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1387)
at com.sun.mail.util.SocketFetcher.configureSSLSocket(SocketFetcher.java:598)
at com.sun.mail.util.SocketFetcher.startTLS(SocketFetcher.java:525)
at com.sun.mail.smtp.SMTPTransport.startTLS(SMTPTransport.java:2041)
… 12 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:387)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292)
at sun.security.validator.Validator.validate(Validator.java:260)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1491)
… 22 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:382)
… 28 more
Did you read this in the documentation:
NOTE: you’ll need to setup Gmail to allow less secured applications. Go here and then click “Allow less secure apps”.
It’s needed for gmail :slight_smile:
Hm… It seems like another issue. Never saw it before. I’ll investigate.
I have done that. Its something else… i will try installing certificates.
@shivasiddharth could you please try to run jar with one more option -Djavax.net.ssl.trustStore
java -Djavax.net.ssl.trustStore -jar server.jar -dataFolder path
Still the same error. The log still looks the same:
… 12 more
… 22 more
… 28 more
Finally figured it out. My avast antivirus was preventing the mail from being sent. I disabled it and it started working. thanks a lot for your support.
