[SOLVED] Button in the app blynk not trigger Arduino output
I was using the example of “Arduino ethernet” and the buttons on blynk app usually They used the outputs of the Arduino. then I added some instructions for using the dht11 sensor, the buttons do not work anymore.
Anyone know how I can fix this?
My cod is this:
#include < SPI.h>
#include < Ethernet.h>
#include < BlynkSimpleEthernet.h>
#include < dht.h>
#define dht_dpin A0 //Pino DATA do Sensor ligado na porta Analogica A1
dht DHT; //Inicializa o sensor
char auth[] = “xxxxxxxxxxxxxxxxxxxxxxxxxxxxx”;
Blynk.begin(auth);
// You can also specify server.
// For more options, see BoardsAndShields/Arduino_Ethernet_Manual example
//Blynk.begin(auth, “your_server.com”, 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8888);
DHT.read11(dht_dpin); //Lê as informações do sensor
float t = DHT.temperature;
char buf[5];
dtostrf(t, 3,0, buf);
Blynk.virtualWrite(V1, String(buf) + “℃”);
float h = DHT.humidity;
char buf[5];
dtostrf(h, 3,0, buf);
Blynk.virtualWrite(V2, String(buf) + “%”);
Hello.
  1. Remove Blynk.run() from setup().
  2. Add
      // Wait until connected
After Blynk.begin(auth);
3. Remove delay from loop and replace with timer. Please go through examples we provided.
would look like?
#include < SPI.h>
#include < dht.h>
#include < SimpleTimer.h>
Blynk.begin(auth);
while(Blynk.connect() == false)
// Aguarde até conectado
Blynk.begin(auth);
char buf[5];
char buf[5];
Here is basic example.
solved: thank you.
the encoded stayed that way.
#include < SPI.h>
#include < dht.h>
char auth[] = “8f1d27f9786941b08b69b9a2ca89f627”;
Blynk.begin(auth);
void sendUptime()
char buf[5];
char buf[5];
Please edit your posts. Code should be formatted.
How to do that:
 ```cpp <--- insert this //cpp means c++
 Paste your code here
 ``` <--- insert this
This makes your code beautiful with highlighted syntax, like this:
void helloWorld()
   String message =  "hello" + "world";
