Soil Moisture Sensor with gauge
Hello
have small problem wants a soil moisture sensor with blynk read only when I with gauge mach shows it at dry 1023 instead of 0 and if damp is 0 on instead of 1023 you can help me
Have this code used under loop:
Serial.println (Sensorvalue);
Sensorvalue = analogRead (A0);
Sensorvalue = map (Sensorvalue, 160,1023,1023,0);
SensorValuePercent = (Sensorvalue / 1023) * 100; // In percent
Delay (3000);
Readup on the Map function:
https://www.arduino.cc/en/Reference/Map
Your issue is here:
Should read:
Sensorvalue = map(Sensorvalue, 0,1023,1023,0);
Edit: Or if that is already your code and its still wrong then just comment out the map function. Or #2, if you are trying to remap min 160 & max 1023 to 0-1023 then its like this:
Sensorvalue = map(Sensorvalue, 160,1023,0,1023);
Format your code correctly like this
``` cpp
CODE
Make sure its 3x ` (backtick)
Hello
Does not work is still displayed at Dry 1023 instead of 0
Right, post the full code and lets have a look.
Hello
the is the code for blynk
int Sensorvalue=0;
int sensorPin=A0;
int sensorValuePercent=0;
WidgetLED led1(V1);
WidgetLED led2(V2);
char auth[] = "6044f1cd5a54cf287de89";
  DebugSerial.begin(9600);
  Blynk.begin(Serial, auth);
 Sensorvalue = map (Sensorvalue,160,1023,1023,0);
sensorValuePercent = (300/1023) * 100; // In Prozent
#upset
/Fettkeewl
Make sure you use THREE (3) backticks for the code… not ONE.
CODE
not
CODE
Right, first mistake is putting the sensor code into the loop, never a good idea and blynk will flood.
Use Simpletimer for reading the sensor every say 20-30mins (its soil moisture after all, it does not change every nanosecond, :slight_smile: )
Edit: Give me a few minutes to go collect a visitor then I’ll rewrite the code.
Oh not delay is used since blynk gets a fault so it does not work
Not exactly. He’s not performing Blynk.virtualWrites() so he not flooding anything. His arduino hardware will be happy enough performing an ADC read and map() in the loop.
The issue is he is relying on the app to read the hardware determined in the widget settings in the app. The INTERVAL time. Default is usually 1 second.
This is okay… but its kinda slack and only works while the app is open. So only good to play with.
@markop, you need to use some virtualpins. Copy the PushData.ino Example (also in your IDE menu). Set it up on your network, with your auth code etc and get it working.
Then change the widget to a gauge.
Then change this part of the code from this:
to this:
Blynk.virtualWrite(V5, analogRead(A0) );
Or just add a new line and change the V5 to V6 etc… then have both (why not eh).
This will update the gauge every 1 sec on the HARDWARE side… far more reliable.
Work from this example from now on and you will be okay.
Leave loop() as it is. Just the 2 lines.
This topic by @Costas is a great place to start! Blynk for Beginners and help with your project
Sorry, you’re right, the code was not tagged so chrome has not shown all of it, grrrr.
instead of
But
No, follow my example above!
Would it be possible that you please me the whole code mailen would be nice beginners on the area
You need to use some virtualpins. Copy the PushData.ino Example (also in your IDE menu). Set it up on your network, with your auth code etc and get it working.
to this:
int Sensorvalue=0;
int sensorPin=A0;
WidgetLED led1(V1);
WidgetLED led2(V2);
char auth[] = "6044f1c889";
 Sensorvalue = map (Sensorvalue,160,1023,200,0);
#upset
/Fettkeewl
you will make people upset if you don’t format your code properly with three ``` backticks at beginning and end…
The code is so correct for gauge
Because in the case of a soil moisture sensor, it indicates dryness instead of 0 1023 and in the case of moist 0 instead of 1023
int Sensorvalue=0;
int sensorPin=A0;
char auth[] = "6044f1c85";
timer.setInterval(3000L, blinkLedWidget);
void blinkLedWidget()
^ Comment inline with your code.
Also does not work the same
Sensorvalue = map(Sensorvalue, 1023,0,1023,0);
or
Sensorvalue = map(Sensorvalue, 1023,0,0,1023);
