I set up Sim900 and Uno to send data to Blynk.
It gets connection and disconnects a lot of times within a minute.
O obseved latency When connected about 900 ms.
I used the code proposed in Blynk library with serialsoftware.
In Blynk dashboard, data are not displayed frequently updated, but hardware is shown on line.
Any help from somebody would be great.
TKS.
Gilmar Oliveira _ Brazil
It is necessary to watch your code
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
#define TINY_GSM_MODEM_SIM900
char auth[] = "xxxxxxxxxx";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(2,3); // RX, TX
TinyGsm modem(SerialAT);
WidgetLED led13(V0);
int iLevelRaw;
int iLevelNorm;
timer.setInterval(5000L, sendUptime_1_0); //LIVE LED
timer.setInterval(10000L, sendUptime_2_0); //Send data
timer.setInterval(2000L, sendUptime_3_0); //Read A0
// Set console baud rate
// Set GSM module baud rate
SerialAT.begin(9600);
delay(3000);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("8486");
void sendUptime_1_0()
if (led13.getValue())
led13.off();
// digitalWrite(13,LOW);
} else
led13.on();
// digitalWrite(13,HIGH);
void sendUptime_2_0()
Blynk.virtualWrite(V1, long(iLevelRaw));
Blynk.virtualWrite(V2, long(iLevelNorm));
void sendUptime_3_0()
iLevelRaw = analogRead(A0);
iLevelNorm = map(iLevelRaw, 0, 1023, 0, 100);
I am using Blynk v0.4.6
Status of conncetion ae as follows:
[11767] Modem init…
[12576] Connecting to network…
[15148] Network: VIVO
[15148] Connecting to …
[31731] Connected to GPRS
[32001] Connecting to blynk-cloud.com:8442
[38523] Ready (ping: 932ms).
[86524] Heartbeat timeout
[87037] Connecting to blynk-cloud.com:8442
[88967] Ready (ping: 886ms).
[94102] Connecting to blynk-cloud.com:8442
[96884] Ready (ping: 1127ms).
… and continues connecting and disconnecting.
Please edit your post and format your code so it looks proper for all of us to read clearly. Thanks
char apn[] = "";
char user[] = "";
char pass[] = "";
int iLevelRaw;
int iLevelNorm;
delay(3000);
modem.restart();
led13.off();
} else
led13.on();
Those ping times are high… that is probably your issue as it also clearly shows a heartbeat error but your code looks OK at a glance,
Thanks for your contribution.
Do you have any suggestion on how to reduce this latency time?
As it will be based entirely on your cellular connection… I would say location and surroundings… does the building the device is in have lots of concrete or metal? Perhaps place it closer to a window, preferably one facing an appropriate cell tower, if you can locate them.
Thank you for your help.
I have placed the GSM/Uno all around my home where good cell signals are available.
I will try another cell company by installing other cell chip in order to check response time.
Nice to talk to you.
Tks.
char apn[] = “”;
Here you need to write what is your connection cellular operator
eg – char apn[] = “internet”;
Your operator may have other options.
Why do not you do so
And remove — timer.setInterval(2000L, sendUptime_3_0); //Read A0
And after a reboot, I would put a delay
modem.restart();
delay(5000);
what is it?
Hi! It’s been a while since last reply but maybe this will help some other users. I’ve struggled with that problem for a long time, and the only solution I’ve found is to switch to Arduino Mega or better. The code is just fine, but it’s like Uno can’t handle it, maybe it runs out of RAM. How much percentage of memory was consumed right after compilation?
