Simple question here. Is there a way I can simply read the value of a virtual pin in the void setup ( ) code set. Background: I want to use virtual pin to save state information as I put the wemos to deepsleep at the end of the setup function.
You can call Blynk.syncVirtual(V0)
. And expect call of BLYNK_WRITE(V0)
thanks Dmitriy.
The issue is I put the wemos to deep sleep at end of void setup () so I assume if I do as per your suggestion BLYNK_WRITE(V0)
will never get called … is this correct assumption ?
BTW: as a matter of interest I don’t understand why there isn’t a simple command to read the value of a virtualpin – what is logic behind not having it ?
@mars look up sync in the docs, it will “recover” variables after deep sleep.
Reading virtual pins is done with the aptly named BLYNK_WRITE() function.
thanks for your help @Dmitriy @Costas - yep got it working but a Blynk.virtualRead would be nice to have I would have thought
BTW: i find the support your and others provide on Blynk Community outstanding ! and in my mind is pivotal to the success of Blynk
This is because Blynk library is asynchronous. syncVirtual(V0)
is virtualRead
indeed. This is just asynchronous paradigm. You need to change your mind set a bit .
