I would like to read the value of the Step Widget at the start without having to physically step the widget on my phone.
Example:
If my Step Widget is set at say 20, now if my ESP8266 has a cold power start I want it to automatically read the value “20” This would apply to a Slider Widget as well
I’m interested in doing the same thing, but this didn’t work for me. Everything runs well and outputs to Serial when I step V3 and V5. But when I hit the “start” button on pin V6, I want it to already have the values from V3 and V5.
char auth[] = "...";
int travelTime;
int motorSpeed;
BLYNK_WRITE(V3)
travelTime = param.asInt(); // assigning incoming value from pin V1 to a variable
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("Travel Time: ");
Serial.println(travelTime);
BLYNK_WRITE(V5)
motorSpeed = param.asInt(); // assigning incoming value from pin V1 to a variable
Serial.print("Motor Speed: ");
Serial.println(motorSpeed);
BLYNK_WRITE(V6)
Serial.print("START! ");
Serial.print(" Travel Time: ");
Serial.print(travelTime);
Serial.print(" Motor Speed: ");
Blynk.begin(Serial, auth);
Blynk.syncVirtual(V3);
Blynk.syncVirtual(V5);
@ChrisPomerleau You should really start your own topic instead of a “Me Too” addon. Your situation could be completely different… as in… aren’t you running via Bluetooth? because Blynk.syncVirtual(Vx);requires a server connection.
