I’ve scrolled through previous reports of push notification problems and tried some of the things that should have solved my issue e.g. uninstall the widget and reinstall.
I’m using latest version of android blynk. Using blynk server. Issuing notification from VB application code using HTTP call. Have the widget set to high priority.
I get the notification OK when blynk is running. When app is in sleep mode the notification is not waking the blynk app. When I wake the blynk app there is still no notification.
my description of when the app is not loaded and visible as a running app on the android. I have swiped it away and need to tap on the blynk icon to see and use my project.
Yes, sleep mode is an accurate enough term, depending on app of course…[quote=“Dave1829, post:4, topic:11673, full:true”]
Im pretty sure the app won’t do anything unless it is running.
[/quote]
If an app is designed to “sleep” the background to some degree (aka notifications) then it is technically still running, just is a sleepier way I have a doorbell app that works that way.
While I haven’t needed to use Blynk notifications myself (aside from experimenting with email notifications), I am under the impression (from other topics, and watching my own experimental MCU sketches) that Blynk also stays somewhat active when in background.
@koaiwi Since someone will probably need to know… what make & model of phone and version of Android are you running. Are you running any battery saver modes on the phone, etc.
I see there is a “built in” notification when hardware goes off-line option (in the notification widget)… have you tried shutting off your MCU to see if that notification works (or not) when your app is sleeping?
Tried this too. The hardware down and push notifications both work when blynk is awake. Both don’t work when blynk is asleep.
I’m raising this as from what I can see the problem is similar or the same as that raised a year ago. It appeared to require a fix. Can someone have a look at it again please.
The function is not as useful if it wont work when the app is asleep but maybe that is just the way it has to work. Can someone confirm one way ot the other. Thanks.
I see you have removed and re-added the notification widget… have you tried uninstalling and reinstalling the whole app itself? Your projects are stored on the server, linked to your account email, so will be restored when you log in anew.
The previous issue also tried to uninstall and reinstall the app with no improvement. So I
think I will wait for @BlynkAndroidDev to have a look at the issue unless he too thinks I should try that or says this is just the way it has to be.
And being a mostly grey bearded technician, I know that value of process of elimination. And speaking of irony, removing and reinstalling the app may have even taken less time/effort than typing the post, stating that you are not going to remove and reinstall the app
