Problems with the local server and Arduino Mega
Hello, I have the following problem:
It turns out that I have an Arduino Mega with a Shield w5100 connected to a local server that I installed in a Raspberry pi 2, this had been working perfectly, that is, I was connected when I wanted to do some work and everything is fine until today, because when I start the server local in the Raspberry well, then in the cell phone, but the case is the Arduino, when I execute a code, I get connected to the server and stays there connecting.
I have already tried updating the blynk libraries, the local server, the android app, even the arduino version I updated it, but it gives me the same problem and I need this urgent, what could it be? Beforehand thank you very much.
I show you what the serial monitor looks like when I run the code.
Your screenshots are basically useless for seeing necessary information :roll_eyes:
Pasting full and properly formatted code here would be better.
What ports are you using for the App & Device (sketch)?
App needs to be 9443
Device needs to be 8080
You may also need to make some changes on your Local Server and/or router.
Thank you very much gunner, the next time I’ll be aware of these new updates, because I had not heard about that, the problem was the port of the arduino :call_me_hand:
