I installed the Blynk server on a Pi 2. Now I am unable to download the Widget-Settings to the Arduino via the play Button.
At the Server installation I had to manually download the blynk-ser.sh script (couldnt find it anyware). After that i changed the SSL-Connection in the script do TCP.
#!/bin/bash
# Detect script path
pushd `dirname $0` > /dev/null
SCRIPTPATH=`pwd`
popd > /dev/null
# === Edit default options to match your need ===
FROM_TYPE="SER" # SER, TCP
TO_TYPE="TCP" # TCP, SSL
COMM_BAUD=9600
SERV_ADDR=192.168.2.108
SERV_PORT_SSL=8441
SERV_PORT_TCP=8442
SERV_PORT_2WAY=8443
LSTN_PORT=8442
The Connection seems to be okay, even the debug lines of the Arduino shows [5075] Ready (ping: 50ms).
Connecting: FILE:/dev/ttyUSB0,raw,echo=0,clocal=1,cs8,nonblock=1,b9600 <-> TCP:192.168.2.108:elay
2017/02/19 12:47:36 socat[4656] N opening character device "/dev/ttyUSB0" for reading and wri
2017/02/19 12:47:36 socat[4656] N opening connection to AF=2 192.168.2.108:8442
2017/02/19 12:47:36 socat[4656] N successfully connected from local address AF=2 192.168.2.10
2017/02/19 12:47:36 socat[4656] N starting data transfer loop with FDs [5,5] and [6,6]
But in the App, there is nothing happening when i press the play button to deploy a test Button.
Were could be my Fault?
