HELP PLZ
Your syntax is incorrect.
Remove the ;
from BLYNK_WRITE(V1);
The proper C++ syntax is
BLYNK_WRITE(V1) {
if( param.asInt() ) {
// code
// code
this is not coding it is copying
I just noticed your setup() has not closing parentheses too.
Which is the }
PLEASE paste your code here and stop posting images.
Copy this example and replace CODE with your entire sketch
```cpp
CODE
@Sai_Khurana the way to start with Blynk is pick the correct sketch provided by Blynk and ensure it works. This way you have working code, then you can add your code to it.
okay!! thanks
which code?
