Compiling Errors
‘param’ was not declared in this scope
sketch_mar13a:21: error: 'param' was not declared in this scope
   int V= param.asInt(V1);
C:\Users\LOGIC ONE\Documents\Arduino\sketch_mar13a\sketch_mar13a.ino: In function 'void BlynkWidgetWrite1()':
sketch_mar13a:68: error: 'pinvalue1' was not declared in this scope
    myservo.write(pinvalue1);
Multiple libraries were found for "Servo.h"
 Used: C:\Users\LOGIC ONE\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.0\libraries\Servo
 Not used: C:\Program Files (x86)\Arduino\libraries\Servo
exit status 1
this is my code
#include <Servo.h>
Servo myservo;
int rfright = 14 ;
int rfmid = 12;
int rfleft = 13;
char auth[] = "a7436918884f406492d4be5e74023032";
char ssid[] = "*******";
char pass[] = "******";
  int right= digitalRead(rfright);
  int left=digitalRead(rfleft);
  int mid= digitalRead(rfmid);
pinMode(rfleft, INPUT);
pinMode(rfmid, INPUT);
pinMode(rfright, INPUT);
 myservo.attach(15);
BLYNK_WRITE(V1) // Run this function when V1 button pressed.
     int pinValue = param.asInt();  // Get status of V1.
    if (pinValue == 1)
    {  // If status of V1 is 1 then do stuff in if().
      void BlynkWidgetWrite1();
    if (pinValue == 0)
if(right == LOW)
        myservo.write(120);
        delay(50);
if(left == LOW)
      myservo.write(30);
    delay(50);
  if (mid == LOW)
      myservo.write(80);
    delay(50);
   int pinValue1 = V;
You declared the variable on the line above as pinValue1 , see the difference?
#include <Servo.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
Servo myservo;
int rfright = 14 ;
int rfmid = 12;
int rfleft = 13;
int pinio =16;
char auth[] = "a7436918884f406492d4be5e74023032";// Your WiFi credentials.
char ssid[] = "@@@;// Set password to " for open networks.
char pass[] = "highlevel";
int piniochange= digitalRead(pinio);
pinMode(pinio, INPUT);
 lcd.begin(16,2);
  lcd.init();
  // Turn on the backlight.
  lcd.backlight();
 myservo.attach(15);
if(piniochange == 1)
if(right == LOW)
        myservo.write(120);
        delay(50);
if(left == LOW)
      myservo.write(30);
    delay(50);
  if (mid == LOW)
      myservo.write(80);
    delay(50);
    if(piniochange == 0);
BLYNK_WRITE(V3)
    myservo.write(param.asInt());
sketch_mar13a:71: error: a function-definition is not allowed here before '{' token
This is not a learn how to code forum.
@Divakar_Pandiyan Please learn and follow the proper way to post code in this forum… any further unformatted posts with be deleted.
Blynk - FTFC
