NodeMCU battery voltage status
@jamin and @elanozturk as you have flashed your ESP’s with an Arduino sketch you no longer have any AT firmware on the ESP.
Uww didn’t know that,thank you! :grin:
I kinda though this but the firmware topic comes up a lot with my vcc reading issue.
@Jamin AT firmware only comes into play when you are using the ESP as a shield for an Arduino not when ESP is working in standalone mode.
Wifi is power hungry, I have found that with an ESP, NodeMCU and a 2000mAh battery I only get a few hours runtime. Using deep sleep to wake up, take samples, publish to MQTT every 5 minutes, I can run for 7-10 days on one cell.
I am working on solar charging using this charge controller: http://www.banggood.com/37V-Liion-Battery-Mini-USB-To-USB-A-Power-Apply-Module-p-928948.html
Make a thread about your project as Im just setting up my own solar projects and would like to follow.
Hi Elan
How would I go about adding this code to my servo code, I keep getting errors,I’ve used the sample servo sketch on Blynk website and use the app but I want to integrate a battery gauge on the app to view the battery voltage of my esp8266 nodemcu board
