Eugene
January 17, 2017, 10:41pm
1
Introducing new look of the project in running mode
Drag & drop widgets over different tabs via the Tabs widget
Finally, while editing your project, you can just swipe or pan to the left to open the Widget Box
Tabs widget look simplified: just tap on the active tab to open the settings
Timer widget Settings screen could show shifted time. This is fixed.
Fixed bug when Slider widget was sending slightly inaccurate value.
As always, please report your feedback regarding the update. Thanks!
Jamin
January 17, 2017, 10:59pm
4
I love the new dash look. Very smooooth!
The best part of this update!
mars
January 17, 2017, 11:22pm
5
Nice update - look forward to seeing parity with android functionally soon ?
With respect to time widget - does that fix the issue (which I also reported a while back) which has the iOS time widget not registering the gmt reference correctly ?
Eugene
January 17, 2017, 11:27pm
6
No, this was more UI issue on settings screen. Timer seems working fine for me. Please reference me to the topic with the issue.
mars
January 18, 2017, 2:13am
7
Just so I’m communicating clearly in terms of what I’m referring too it is this issue reported some time ago : Blynk getStart/StartHour/Minute/Sec function return GMT+0 always
Is this what you were referring too in your last response ?
Jamin
January 18, 2017, 2:30am
8
Having issues with cloning a project.
This is the screen im shown for all my projects.
It crashes a few seconds after opening the clone project page.
Eugene
January 18, 2017, 2:43am
9
The bug you referring is about Time Input (not Timer) and I believe already fixed
Eugene
January 18, 2017, 2:45am
10
Got the crash report. It crashed after you tapped “Share” right?
Jamin
January 18, 2017, 3:05am
11
It crashes when i just sit on that page too.
I’ll do it now and hope it sends crash report.
EDIT: No youre correct… it only crashes when you click SHARE.
Any reason why the QR code doesnt show up?
mars
January 18, 2017, 8:45am
12
ok - sorry confused timer input for timer, my bad
Eugene
January 18, 2017, 9:54pm
13
Could not reproduce that. It may take some time, but always shows up. If this still reproduces on your project, please share with me (private msg) the device token.
Jamin
January 18, 2017, 10:20pm
14
Im on local server if that matters?
Eugene
January 18, 2017, 10:37pm
15
Yep, then no point, it will be useless for me
