Is it possible to make the Timer widget changeable without stopping the proces? Something like the time input widget? That would be great. Then when I share the project, someone can change the timer but can not do other things.
Works great!! Only observation is that, in step mode, the counter should either be blank or display actual 1 / -1 step value; Just to keep the button masher from getting confused as to what value (or what mode) the widget is actually sending out
I noticed the same. Rebooting my phone (just to be sure) worked for me (so far). Side question: I’m having a hard time moving widgets between tabs… They’re intermittently getting stuck on the tab!
I’ve been able to reproduce the widget on tab issue a few times. Unfortunately the only way to fix is to move the tab bar which is time consuming when screens are full!
I don’t think Blynk has that much sway over Google (whom for whatever reason has not opened up Play Store in Georgia - The Country, at this time).
However, have you tried searching for the Blynk.apk? I found a slightly older one listed here, current version should show up eventualy… downloads and installs fine on my Droid4X sandbox. Run your own AV scans to be sure.
We found one issue that could fail home screen widgets work on any server, tomorrow or on friday - we’ll release a fix. I’ll attach here a new apk for you.
In terms of Blynk settings, I have the alert priority set on Normal and set to warn if the device goes offline.
Do Not Disturb mode automatically silences notifications at night so your phone doesn’t blink, buzz or ring while you sleep. The Blynk app somehow bypassed this and was making my phone buzz, I’ll admit my device doesn’t go offline very often or at all so I don’t know if this is an issue with just this version or not.
Thank you for help
As I know, when application is published only developer is able to restrict Countries.
I have downloaded latest version using TOR Browser(as if I was downloading it from EU Country).
I need to buy Blynk Energy, but I got error on this also:
