Tell me everything is correct?
The LedFader library is changed under ESP8266. If anyone is interested, I can then publish!
#include <Ticker.h>
Ticker ticker;
#include <LEDFader.h>
LEDFader led = LEDFader(14);
#include <OneWire.h>
#define ONE_WIRE_BUS 5
#include <ArduinoOTA.h>
#define PirLed 2
#define PirPin 4
int newTimer = 1;
int TimerPirOnOff = 2;
int TimerCounter = 3;
int TimerSendTemp = 4;
int Newcounter = 0;
boolean PrivCounter = false;
long PirOff;
long FaderIn;
long FaderOut;
boolean PirPrewState = false;
char auth[] = "*****";
char ssid[] = "*****";
char pass[] = "*****";
ArduinoOTA.setHostname("PIR-Sensor");
ArduinoOTA.begin();
Blynk.begin(auth, ssid, pass, "192.168.1.100");
led.fade(255, 0);
pinMode (PirLed, OUTPUT);
digitalWrite(PirLed, LOW);
pinMode (PirPin, INPUT);
sensors.begin();
TimerPirOnOff = timer.setInterval(500, PirStateOnOff);
TimerCounter = timer.setInterval(1000, Counter);
TimerSendTemp = timer.setInterval(10000, SendTemp);
BLYNK_CONNECTED()
Blynk.syncAll();
BLYNK_WRITE(V4)
FaderIn = param.asInt()*1000 ;
Blynk.virtualWrite(V5, String(FaderIn/1000)+" сек");
BLYNK_WRITE(V6)
FaderOut = param.asInt()*1000 ;
Blynk.virtualWrite(V7, String(FaderOut/1000)+" сек");
BLYNK_WRITE(V0)
PirOff = param.asInt()*1000;
Blynk.virtualWrite(V1, String(PirOff/1000)+" сек");
BLYNK_WRITE(V3)
int resetCounter = param.asInt();
if (resetCounter)
Newcounter = 0;
void SendTemp()
float temp = sensors.getTempCByIndex(0);
Blynk.virtualWrite(V8, String(temp, 2)+"℃");
void PirStateOnOff()
if(digitalRead(PirPin)== HIGH && PirPrewState == false)
PirLedOn();
void Counter()
if(digitalRead(PirPin)== HIGH && PrivCounter == false)
Newcounter +=1;
PrivCounter = true;
if(digitalRead(PirPin)== LOW && PrivCounter == true)
Blynk.virtualWrite(V2, String(Newcounter)+" Раз");
void PirLedOn()
led.fade(0, FaderIn);
ticker.attach(0.06, tick);
newTimer = timer.setTimeout(PirOff,PirLedOff);
PirPrewState = true;
Blynk.virtualWrite(V9, "ВКЛ");
void PirLedOff()
ticker.detach();
led.fade(255, FaderOut);
Blynk.virtualWrite(V9, "ВЫКЛ");
void tick()
//toggle state
int state = digitalRead(PirLed); // get the current state of GPIO1 pin
digitalWrite(PirLed, !state); // set pin to the opposite state
ArduinoOTA.handle();
led.update();
