Thanks for new vervion with multiple devices control! But, on page Project settings in devices list I can’t delete created device.
Do you see some error or just nothing happens? Does logout/login help?
Yes, login/logout help me, and now when I add new device, on page My Devices token not generate: " Updating token…" Refresh dosen’t help. I use local server.
This latest server right?
0.20.1 -right?
Yeap. This is latest. We will check this issue. Thank you for posting.
Note: when I create new device at first time, I pushing the Refresh button and token is there!
Already fixed. Will be in next update.
hi - I have a project with two devices. Originally it was only with arduino mega and all widgets were associate with this device.
Then I added a second device, Wemos and I changed each widget to link from the mega to wemos.
Now I wish to delete the mega from the project but I cannot seem to do so - can it be done (or am i missing something) ?
Hello. You can’t. Due to back compatibility with older app versions we added this restriction (later it will be removed). However right now you can remove Wemos and rename first device to wemos.
got it - thank you.
