MQ-2 sensor
I have a a MQ-2 sensor which is a smoke and gases detection is there any idea how to write the arduino id code and which library sholud i install and help for this project.
regards
Arduino Playground - HomePage & http://www.instructables.com/id/How-to-use-MQ2-Gas-Sensor-Arduino-Tutorial/
Google :wink:
I could not found any useful code
where did you try to find code?
i see that in instructables link above is a simple code for this sensor. just needs reading an analog pin…
also, if you mind to read the comments on instructable page, there are even more details how to interpret the analog reading.
The idea is that i am using a nodemcu esp8266 not an ardunio chip and the esp is connected to the blynk so the code must read the data from the sensor attached to the esp and show it on the blynk
Actually most code you find online relating to “arduino” can also be directly used on ESP dev boards (such as the nodemcu, wemos etc).
Please post a screenshot of the sensor data in the Serial monitor on the ESP with no Blynk.
This official help document should guide you through everything: http://help.blynk.cc/blynk-basics/how-to-display-any-sensor-data-in-blynk-app
You can use Arduino code on the NodeMCU… You should look into learning how to do that before anything else.
Or stick with Lua script, but I don’t think Blynk works natively with Lua?
I found this sketch and it works for me well maybe you can use it. I use a esp8266-01 and MQ-2 sends a notification when it detects gas, greetings
#include <Ethernet.h>
// Go to the Proje  ct Settings (nut icon).
char auth[] = "xxxxxxxxx"; //
int buttonStatePrev;
  Blynk.begin(auth, "xxxx", "xxxxxxxx");
// Wait until connected
  pinMode(3, INPUT);
  buttonStatePrev = HIGH;
int buttonStateCurr = digitalRead(3);
  if (buttonStateCurr == LOW && buttonStatePrev == HIGH) {
   Serial.println("Button is held down but activated the function only ONCE.");
   buttonStatePrev = buttonStateCurr;
   delay(50);
if (buttonStateCurr == HIGH && buttonStatePrev == LOW) {
Serial.println("Alerta, se ha detectado gases inflamables");
Blynk.notify ("Alerta, se ha detectado gases inflamables");
delay(50);
but have not you use any libraries only this code ?
in other work what did you include above in the code
@hkjavier, please edit your post and format your code using the template below
```cpp
CODE
Already in code format with libraries
correct!!!
that is the beauty of such a simplistic sensor - it sends value of 0 to 1023 or LOW/HIGH depending on what breakout board you have…
it is ENTIRELY up to you to decide what you do with that information :wink:
ok that is good and , just a simple question is it possible for example if i want to represent the percentage of the gas exist on the blynk screen ?
No, because it doesn’t sound like you have calibrated it?
Google “calibration mq-2” for methodology…
But you can do “backyard” calibration too…
pinMode(3, INPUT);
I did not get this , which pin was the sensor conncted to ESP
