Missing something with attempt to understand Advanced Time Input
I just realised that this ^ command, as well as the stop time one, needs to be in a BLYNK_WRITE() Function tied to the Time Input Widget… so you should transfer/store all the if t.hasStartTime()… etc… into separate variables to be ran in my if() code.
e.g.
BLYNK_WRITE(V1) {  // Time Input Widget
  TimeInputParam t(param);
  SThour = t.getStartHour();
  STmin = t.getStartMinute();
  SPhour = t.getStopHour();
  SPmin = t.getStopMinute();
void TimeCheck() {  // call with timer every 30 seconds or so
  if (hour() == SThour) {
    if (minute() == STmin) {
      Serial.println("Doing something now");
    } else if (minute() < STmin) {
      Serial.println("Will do something");
    } else if (minute() > STmin) {
      Serial.println("Did something");
      Serial.println("Clueless");
  if (hour() == SPhour) {
    if (minute() == SPmin) {
      Serial.println("Stopping something now");
    } else if (minute() < SPmin) {
      Serial.println("Will stop something");
    } else if (minute() > SPmin) {
      Serial.println("Stopped something");
LOL you did read this part of my reply?:sweat_smile:
Ok, thank you. I will see what I can figure out
I understand… it has taken me the last 3+ hours to get this far… :stuck_out_tongue: But I wanted to finally figure out this Time Input Widget for myself… so your welcome :slight_smile:
And I am working on a more fleshed out example… eventually :timer_clock: :wink:
I may still be sitting here when you come up with your example, albeit without any hair left on my head.
Thanks again. Ill keep plugging away. Seems as though I am not the only one to struggle with this one.
Here is something else that confuses me though. I look at the sketch builder and find an example for Advanced Time Input. If I load this sketch and add a Time Input widget, it would seem to me it will do nothing. But, shouldn’t I be able to just add a digitalWrite somewhere in the code based on the time trigger? Otherwise, what is the point of this example? Plus there is no mention of needing the RTC widget in the docs or example sketch when using the Time Input widget. I dont understand why I need RTC at all when there is already a provision to set the time zone in the Time Input widget and I cannot find an explanation anywhere?
That is a template that contains this extract of code:
Serial.println(String("Start: ") +
               t.getStartHour() + ":" +
               t.getStartMinute() + ":" +
               t.getStartSecond());
This give you the trigger time but you need all the extra code like RTC to check if the time now is < == > than trigger time etc.
I need to digest that a bit. In the serial monitor when I change time zones, I see it update correctly to the time zone i choose in the widget. Same for the day of the week, if I change it in the widget, I see it updated in serial monitor. One issue though, in terminal widget assigned to V1 as in the code I am using, the only message I ever see is 'Scheduler1 not active today".Still trying to figure that out
Could be the library hack that you are missing but that should only be required to switch no days selected to actually meaning no days, rather than the Blynk default of no days means everyday.
Do you have all days selected in the widget as that’s best for testing?
Yes, I have tried every possible choice for days, all days, no days, actual day, day before only, day after only. You are correct though, I do not have the hack and I see ALL days when NO days are selected
I agree wholeheartedly… most current examples offer semi-theoretical use cases, fine for those that can handle some coding, but no good for those that literally want a copy/paste “Pushenzee buttons and watchenzee blinkin lights” example.
However, I believe the developers are working on some totally improved & advanced Sketch Builder routines…
Meanwhile, here is my “final”? relatively copy/paste-able, start and stop time only (all days of the Week), shows stuff and toggles a digital pin (built-in LED on Wemos D1 Mini), example :stuck_out_tongue:
#include <WidgetRTC.h>
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxx";
char currentTime[9];
char startTime[9];
char stopTime[9];
int SThour;
int STmin;
int STsec;
int SPhour;
int SPmin;
int SPsec;
WidgetRTC rtc;  // Set RTC widget.
  pinMode(2, OUTPUT);  // Built-in LED
  digitalWrite(2, HIGH); // Turn OFF built-in LED
  Serial.begin(115200);  // Debug console
  rtc.begin();
  setSyncInterval(360);
  timer.setInterval(30000L, TimeCheck);  // Update Time Check every 30 seconds
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V1); //  Synchronize Time Input Widget when connected
  TimeCheck(); // Initial Time Check
BLYNK_WRITE(V1) {  // Called whenever setting Time Input Widget
  STsec = t.getStartSecond();
  SPsec = t.getStopSecond();
  // Get RTC time
  sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second());
  Serial.print("Current Time: ");
  Serial.println(currentTime);
  // Get Time Input Widget time
  sprintf(startTime, "%02d:%02d:%02d", SThour, STmin, STsec);
  Serial.print("Start Time: ");
  Serial.println(startTime);
  sprintf(startTime, "%02d:%02d:%02d", SPhour, SPmin, SPsec);
  Serial.print("Stop Time: ");
      digitalWrite(2, LOW); // Turn ON built-in LED
  Serial.println("----------");
[5887]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.5.0 on Arduino
[5893] Connecting to 10.10.3.13:8442
[10894] Connecting to 10.10.3.13:8442
[10923] Ready (ping: 19ms).
[11069] Time sync: OK
Current Time: 12:40:21
Start Time: 12:41:00
Stop Time: 12:42:00
Will do something
Will stop something
Current Time: 12:40:51
Stop Time: 12:42:00
Will do something
Will stop something
Current Time: 12:41:21
Stop Time: 12:42:00
Doing something now
Will stop something
Current Time: 12:41:51
Stop Time: 12:42:00
Doing something now
Will stop something
Current Time: 12:42:21
Stop Time: 12:42:00
Did something
Current Time: 12:42:51
Stop Time: 12:42:00
Did something
Current Time: 12:43:21
Stop Time: 12:42:00
Did something
Stopped something
Try the EziScheduler at Time input widget and eventor without any changes.
There are a couple of revisions after this version and the library hack but they are only required for rare case events.
@costas I have iOS so I do not have access to Eventor widget. So if I understand correctly, then I will not be able to follow this example but I will check it out, Thank you
@Gunner I appreciate the code you have provided, Thank you I will give it a try. BTW, I am not complaining at all.Without Blynk cut and paste programmers like me would have never become interested in coding, IOT etc. Like everything new, it can be confusing and frustrating.
The sketch doesn’t use Eventor.
I see that now since I have looked at the code. Was thrown by the title! I am loading it now
Not bad for a first shot :slight_smile:
@Costas the code you referred me to worked as expected. I assigned the Time Input widget to V1 and an LED to V0. When the start time triggered, the LED was HIGH and I saw the print out in serial monitor. Awesome, Thank you. Now, I shall proceed to test the code that @Gunner provided. Thank you both very much. I then need to spend some time to try to understand what is going on in the code.
Well, I felt good about it until I saw yours :blush:
How did I miss that the first time around?? Oh well… this is how I learn :smiley:
Dunno but I have posted it several times and added minor tweaks as I will highlight below.
@mpo881 the library hack is just a couple of characters and documented at TimeInput Widget delivers ALL days selected when no day is selected - #7 by Darwini
The hack makes no days selected actually mean " I have selected no days as it’s the quickest way of doing scheduling without changing or resetting the times as I might want the same times in the future".
dayadjustment variable is required because Blynk start the week on a different day to the popular Time Library.
As per the library hack I just disable days with the Widget rather than using the reset time facility. Reset time facility means OFF.
I always thought that computers work with 0 and 1’s with 0 meaning OFF and 1 meaning ON but it turns out I was wrong. For Blynk computers off is -1 as documented from about post #66 at RF 433 Mhz on virtual pin doesn't want to send (with scheduling) - #66 by Costas
In the version of code I posted in that thread we were using unsigned int for variables associated with time and wrongly assuming no time or off would be zero. No time, as created with the reset facility, is actually -1 and therefore crashes the ESP with an unsigned int.
So you need to change:
  unsigned int nowseconds = ((hour() * 3600) + (minute() * 60) + second());
  unsigned int startseconds = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
  unsigned int stopseconds = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
To:
@Gunner your code worked fine and toggled the built in LED at the chosen time triggers-Thank you!
@Costas thanks for the explanation and links to the hack. I will be reading this all for a bit yet trying to wrap my head around it all.
THANK YOU BOTH for your time and help.
