yup put it behind a timer at 500ms, then make sure you set a boolean after you send the email so that it only sends once.
void monitorFridge(){
if (tempCong >= -8 && !sentNotice)
//Blynk.notify("Temperatura alta!");
Blynk.email("rodrigo.cavalheiro@gmail.com", "Alerta de temperatura", "Câmara de congelados acima de -8C!");
sentNotice= 1; // mark it sent so it doesnt loop and flood
} else if(tempCong != -8) {
sentNotice= 0;
I can read the temperatures in the app but I don’t receive the emails.
Please notice that there are 2 temp sensors.
Both boolean variables were declared correctly.
My code:
// Set console baud rate
// Set ESP8266 baud rate
DS18B20.begin();
DS18B20B.begin();
timer.setInterval(5000L, sendTemps); // Temperature sensor polling interval (5000L = 5 seconds)
void sendTemps()
DS18B20.requestTemperatures(); // Polls the sensors
DS18B20B.requestTemperatures();
tempCong = DS18B20.getTempCByIndex(0); // Gets first probe on wire in lieu of by address
tempResf = DS18B20B.getTempCByIndex(0);
Blynk.virtualWrite(4, tempCong);
Blynk.virtualWrite(5, tempResf);
if (tempCong >= -8 && !sentNotice1)
sentNotice1= 1; // mark it sent so it doesnt loop and flood
} else if(tempCong < -8) {
sentNotice1= 0;
if (tempResf >= 11 && !sentNotice2)
Blynk.email("rodrigo.cavalheiro@gmail.com", "Alerta de temperatura", "Câmara de congelados acima de 11C!");
sentNotice2= 1; // mark it sent so it doesnt loop and flood
} else if(tempResf < 11 ) {
sentNotice2= 0;
timerFridge.run();
Blynk.email("rodrigo.cavalheiro@gmail.com", "Congelados > Alerta de temperatura", "Câmara de congelados acima de -8C!");
sentNotice1= 0;
Blynk.email("rodrigo.cavalheiro@gmail.com", "Refrigerados > Alerta de temperatura", "Câmara de refrigerados acima de 11C!");
sentNotice2= 0;
Also, I put a timerFridge.setInterval(5000L, monitorFridge); in void setup()
#define ONE_WIRE_BUS 10
#define TWO_WIRE_BUS 11
#include <OneWire.h>
#include <ESP8266_Lib.h>
#include <TimeLib.h>
OneWire twoWire(TWO_WIRE_BUS);
DallasTemperature DS18B20B(&twoWire);
char auth[] = "token";
char ssid[] = "RingOfFire";
char pass[] = "xxxxxxx";
//variables
float tempCong;
float tempResf;
boolean sentNotice1;
boolean sentNotice2;
SimpleTimer timerFridge;
//#define EspSerial Serial1
#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
DS18B20.begin();
DS18B20B.begin();
void sendTemps()
timerFridge.run();
sentNotice1= 0;
sentNotice2= 0;
//variables
float tempCong;
float tempResf;
DS18B20.begin();
DS18B20B.begin();
timer.setInterval(5000L, monitorFridge);
void sendTemps()
void monitorFridge() {
sentNotice1 = 1; // mark it sent so it doesnt loop and flood
else if (tempCong < -8)
sentNotice1 = 0;
sentNotice2 = 1; // mark it sent so it doesnt loop and flood
else if (tempResf < 11 )
sentNotice2 = 0;
you should add in some serial prints to see if/where the code is not working…
serial.Print(F("temp is high! just tried to send email"));
serial.Print(F("temp is OK! no need to send email"));
sentNotice1 = 0;
sentNotice2 = 0;
I changed the code to include serial prints, tried to change the email but email still not working.
Serial monitor:
[19] Blynk v0.3.10 on Arduino Uno
[520] Connecting to Papa-Rica Wi-Fi
[3585]
OK
[6727] 192.168.1.100
[6757] Connected to WiFi
temp is high! just tried to send email[14504] Login timeout
[26024] Login timeout
[36716] Login timeout
[46937] Ready (ping: 1589ms).
Even when I try to send a “Success login” notification or email on void setup() it completely ignores the command.
Do I have to call any library for notifications or email?
Output from last code:
[525] Connecting to Papa-Rica Wi-Fi
[3592] 0018000902-AI03
[6731] 192.168.1.100
[6761] Connected to WiFi
[14529] Login timeout
[25542] Ready (ping: 1588ms).
[43947] Heartbeat timeout
[53080] Ready (ping: 1589ms).
[138557] Login timeout
that is hard, it is easier to see if temp is above X every Y minutes.
otherwise you have to start using an average or median to know if the temperature STAYS above X
in my HVAC code, i use runningMedian to smooth out my temps and know that when i look at the temps every X minutes, i know that the temps is not an aberration, so it is reliable enough to use to make decisions…
or more simply you can check temp every X/5 minutes and keep a count of how many times during X the temp is higher than Y - if it is higher than Y 5 times, then trigger your warnings…???
My code (didn’t change too much according to the last code):
char auth[] = "TOKEN";
char ssid[] = "Papa-Rica Wi-Fi";
char pass[] = "password";
//variables
float tempCong;
float tempResf;
DS18B20.begin();
DS18B20B.begin();
timerFridge.setInterval(10000L, monitorFridge);
void sendTemps()
timerFridge.run();
if (tempCong >= -7 && !sentNotice1)
else if(tempCong < -7)
sentNotice1= 0;
sentNotice2= 0;
About your suggestion:
This is exactly what I want.
I’m working on it. If you have any advice, please share it!
Thank you!
If the temperature is over X, trigger the temperature timer.
|20°c 10secs|
|TRIGGERED| <=Not like this.
The temperature timer should check every D secs till It exceeds Y. (Where D is a constant integer lower than Y, 2 is recommended)
If it falls before Y, stop.
If it exceeds Y, send the e-mail.
