@Ze_Pico Ah, ok. The temporary fix for seconds is:
Brazil = 4294952896
Mnus 2 to the power 32 = -4294967296
= -14400
= -4 hours
Brazil = 4294952896
= -14400
= -4 hours
@Dmitriy
your choice was for the simple time input where there is no time zone
but here we are discussing the advance time input sketch.
BLYNK_WRITE(V1) {
TimeInputParam t(param);
// Process start time
if (t.hasStartTime())
Serial.println(String("Start: ") +
t.getStartHour() + ":" +
t.getStartMinute() + ":" +
t.getStartSecond());
else if (t.isStartSunrise())
Serial.println("Start at sunrise");
else if (t.isStartSunset())
Serial.println("Start at sunset");
// Do nothing
// Process stop time
if (t.hasStopTime())
Serial.println(String("Stop: ") +
t.getStopHour() + ":" +
t.getStopMinute() + ":" +
t.getStopSecond());
else if (t.isStopSunrise())
Serial.println("Stop at sunrise");
else if (t.isStopSunset())
Serial.println("Stop at sunset");
// Do nothing: no stop time was set
// Process timezone
// Timezone is already added to start/stop time
Serial.println(String("Time zone: ") + t.getTZ());
// Get timezone offset (in seconds)
Serial.print(String("Time zone offset: ") + t.getTZ_Offset()/3600);
Serial.println(String(" Hour(s)"));
// Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
for (int i = 1; i <= 7; i++) {
if (t.isWeekdaySelected(i)) {
Serial.println(String("Day ") + i + " is selected");
Serial.println();
thanks, you are correct.
Should work now on master branch
@vshymanskyy
hi,
same as before
on local and cloud servers
“simple time input” is OK but not the “advance time input” sketch.
[19553] Ready (ping: 0ms).
Start at sunrise
Stop at sunrise
Time zone: Pacific/Samoa
Time zone offset: 4294927696
Day 4 is selected
You have to use latest version from github
@vshymanskyy
i tested it from
https://github.com/blynkkk/blynk-library/tree/master/examples/Widgets/TimeInput/AdvancedTimeInput
this example is for arduino, i adjusted it for nodeMCU
the result is same as above
I don’t know what am i missing?
@Ze_Pico I think what @vshymanskyy is saying is you need the Blynk library from the master not an example sketch.
yes Costas you are write.
i thought i was using the latest library 0.4.6 but I found new modification from 3 days
thanks Costas
@vshymanskyy
thanks a lot.
one more favour can you pls. find for me a simple sketch for activating an output on sunset and deactivating it on sunrise, as all sketches I found are long and complex.
@Ze_Pico look up the TimeLord.h or the SunLight.h libraries for your local sunrise and sunset times to use alongside the TimeInput widget.
I tested it before (post:33) 4 inputs are required and they all affect the result.
I hope I can find a simple algorithm handling all variables.
