//wemos d1 mini
//SLOVAKIA
//Vladimir Minar
//22.3.2017
#include <OneWire.h>
#define ONE_WIRE_BUS 1//D1-GPIO1 TX //DS18B20
DeviceAddress tempSensor1 = { 0x28, 0x19, 0xAE, 0xB0, 0x01, 0x00, 0x00, 0x78 };//adres dallas DS18B20 TYPE
DeviceAddress tempSensor2 = { 0x28, 0xF9, 0x1E, 0xB1, 0x01, 0x00, 0x00, 0x91 };//adres dallas
DeviceAddress tempSensor3 = { 0x28, 0xFF, 0xBE, 0x02, 0x3E, 0x04, 0x00, 0xB3 };//adres dallas
int temperature1, temperature2, temperature3;
char auth[] = "XXX";
char ssid[] = "XXX";
char pass[] = "XXX";
/**************RELAY********************************/
const int relay1 = 15;//D8-GPIO15 relay1 gate1
const int relay2 = 12;//D6-GPIO12 relay2 gate2
const int relay3 = 14;//D5-GPIO14 relay3 light1
const int relay4 = 16;//D0-GPIO16 relay4 light2
/**************BUTTON************************/
const int button1 = 3;//GPIO3 RX button1 gate1 monostabil
const int button2 = 0;//D3-GPIO0 button2 gate2 monostabil
const int button3 = 2;//D4-GPIO2 button3 light1 bistabil
const int button4 = 13;//D7-GPIO13 button3 light2 bistabil
const int magneticswitches1 = 5;//D1-GPIO5 input button gnd /gate 1 open/magneticswitches
const int magneticswitches2 = 4;//D2-GPIO4 input button gnd /gate 2 open/magneticswitches1
void physicalbutton(); //physical button
int relaystate3 = LOW; //relayState3
int relaystate4 = LOW; //relayState4
int buttonstate3 = HIGH;//buttonState3
int buttonstate4 = HIGH;//buttonState4
WidgetLED led1(V5); // led monostabil gate1
WidgetLED led2(V6);// led monostabil gate2
//WidgetLED led3(V7);//light bistabil
//WidgetLED led4(V8);//light1 bistabil
WidgetLED led5(V9);//led online
WidgetLED led6(V10);////garage 1 open/
WidgetLED led7(V11);//garage 2 open/
// temperature1 V12
// temperature2 V13
// temperature3 V14
WidgetLCD lcd(V15);
//VALUE DISPLAY online V16
//VALUE DISPLAY magneticswitches GATE V17
//VALUE DISPLAY magneticswitches GATE2 V18
boolean buttonstate1 = false;//button1 magneticswitches gate 1
boolean buttonstate2 = false;//button2 magneticswitches gate 2
/******************input button gnd /garage open**************/
void ledmagneticswitches1()
boolean isPressed = (digitalRead(magneticswitches1) == LOW);
if (isPressed != buttonstate1) {
if (isPressed) {
led6.on();
Blynk.virtualWrite(V17, "OPEN");
lcd.print(1, 0, "GARAGE OPEN");
Blynk.email("XXX@gmail.com", "GARAGE OPEN!", "Garage open.");
led6.off();
Blynk.virtualWrite(V17, "CLOSE");
lcd.print(1, 0, "GARAGE CLOSE");
buttonstate1 = isPressed;
/********input button gnd garage 1 open*****************************/
void ledmagneticswitches2()
boolean isPressed = (digitalRead(magneticswitches2) == LOW);
if (isPressed != buttonstate2) {
if (isPressed) {
led7.on();
Blynk.virtualWrite(V18, "OPEN");
lcd.print(1, 1, "GARAGE1 OPEN");
Blynk.email("XXX@gmail.com", "GARAGE1 OPEN!", "Garage1 open.");
led7.off();
Blynk.virtualWrite(V18, "CLOSE");
lcd.print(1, 1, "GARAGE1 CLOSE");
buttonstate2 = isPressed;
BLYNK_CONNECTED() {
Blynk.syncVirtual(V1);
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
Blynk.syncVirtual(V4);
/************MONOSTABIL push button android*************/
BLYNK_WRITE(V1)
if (param.asInt())
digitalWrite(relay1, HIGH);
led1.on();
digitalWrite(relay1, LOW);
led1.off();
/**********MONOSTABIL push button android*******************/
BLYNK_WRITE(V2)
if (param.asInt())
digitalWrite(relay2, HIGH);
led2.on();
digitalWrite(relay2, LOW);
led2.off();
/*****************BISTABIL switch button android***************/
BLYNK_WRITE(V3)
if (param.asInt())
digitalWrite(relay3, HIGH);
digitalWrite(relay3, LOW);
/**************BISTABIL switch button android**************/
BLYNK_WRITE(V4)
if (param.asInt())
digitalWrite(relay4, HIGH);
digitalWrite(relay4, LOW);
/**********MONOSTABIL***************/
int sensorVal = digitalRead(3);
Serial.println(sensorVal);
if (sensorVal == HIGH) {
digitalWrite(15, LOW);
Blynk.virtualWrite(V1, LOW);
led1.off();
digitalWrite(15, HIGH);
Blynk.virtualWrite(V1, HIGH);
led1.on();
/**********MONOSTABIL*************/
int sensor1Val = digitalRead(0);
Serial.println(sensor1Val);
if (sensor1Val == HIGH) {
digitalWrite(12, LOW);
Blynk.virtualWrite(V2, LOW);
led2.off();
digitalWrite(12, HIGH);
Blynk.virtualWrite(V2, HIGH);
led2.on();
/**********BISTABIL**************/
if (digitalRead(button3) == LOW) {
if (buttonstate3 != LOW) {
relaystate3 = !relaystate3;
digitalWrite(relay3, relaystate3);
Blynk.virtualWrite(V3, relaystate3);
buttonstate3 = LOW;
/**********BISTABIL***************/
if (digitalRead(button4) == LOW) {
if (buttonstate4 != LOW) {
relaystate4 = !relaystate4;
digitalWrite(relay4, relaystate4);
Blynk.virtualWrite(V4, relaystate4);
buttonstate4 = LOW;
/***ONLINE*************/
void ledonline()
if (led5.getValue()) {
led5.off();
Serial.println("LED on V9: off");
Blynk.virtualWrite(V16, "ERROR");
led5.on();
Serial.println("LED on V9: on");
Blynk.virtualWrite(V16, "ONLINE");
void sendSensor1() {
temperature1 = sensors.getTempC(tempSensor1);
Blynk.virtualWrite(V12, temperature1);
void sendSensor2() {
temperature2 = sensors.getTempC(tempSensor2);
Blynk.virtualWrite(V13, temperature2);
void sendSensor3() {
temperature3 = sensors.getTempC(tempSensor3);
Blynk.virtualWrite(V14, temperature3);
void setup(){
Blynk.email("XXX@gmail.com", "online", "wemos d1 mini je online.");
pinMode(relay1, OUTPUT);//relay1
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
pinMode(button1, INPUT_PULLUP);//button1
pinMode(button2, INPUT_PULLUP);
pinMode(button3, INPUT_PULLUP);
pinMode(button4, INPUT_PULLUP);
pinMode(magneticswitches1, INPUT_PULLUP);//input button gnd /garage open/
pinMode(magneticswitches2, INPUT_PULLUP);//input button gnd /garage 1 open/
timer.setInterval(500L, ledmagneticswitches1);
timer.setInterval(500L, ledmagneticswitches2);
timer.setInterval(1000L, physicalbutton);
timer.setInterval(1000L, ledonline);
sensors.begin();
sensors.setResolution(tempSensor1, 10);
sensors.setResolution(tempSensor2, 10);
sensors.setResolution(tempSensor3, 10);
timer.setInterval(5000L, sendSensor1);
timer.setInterval(4800L, sendSensor2);
timer.setInterval(4500L, sendSensor3);
What is this?
Garage Control temperature and light control
You should edit your first post and include more details about the project, otherwise this thread is kinda pointless and will just fall to the bottom.
Include a written description, links to reference, QR code of the clone Blynk project, and maybe a github repo.
//DS18B20 OTHERWISE
void readTemp()
char t_buffer0[15];
char t_buffer1[15];
char t_buffer2[15];
float floatTempC0 = sensors.getTempCByIndex(0);
float floatTempC1 = sensors.getTempCByIndex(1);
float floatTempC2 = sensors.getTempCByIndex(2);
dtostrf(floatTempC0, 8, 9, t_buffer0);
dtostrf(floatTempC1, 8, 9, t_buffer1);
dtostrf(floatTempC2, 8, 9, t_buffer2);
if(floatTempC0 != -127) Blynk.virtualWrite(V12, t_buffer0);
if(floatTempC1 != -127) Blynk.virtualWrite(V13, t_buffer1);
if(floatTempC2 != -127) Blynk.virtualWrite(V14, t_buffer2);
indent preformatted text by 4 spaces
More on resolutions:
http://www.homautomation.org/2015/11/17/ds18b20-how-to-change-resolution-9101112-bits/
push message
//6x temperatures
DeviceAddress tempSensor1 = { 0x28, 0xB0, 0x68, 0x15, 0x06, 0x00, 0x00, 0x7E };//adres dallas DS18B20 TYPE
DeviceAddress tempSensor2 = { 0x28, 0x70, 0x6A, 0x15, 0x06, 0x00, 0x00, 0x52 };//adres dallas
DeviceAddress tempSensor3 = { 0x28, 0x2A, 0x30, 0x15, 0x06, 0x00, 0x00, 0x7B };//adres dallas
DeviceAddress tempSensor4 = { 0x28, 0x19, 0xAE, 0xB0, 0x01, 0x00, 0x00, 0x18 };//adres dallas DS18B20 TYPE
DeviceAddress tempSensor5 = { 0x28, 0x7F, 0xB8, 0xB0, 0x01, 0x00, 0x00, 0xE7 };//adres dallas
DeviceAddress tempSensor6 = { 0x28, 0xFF, 0xBE, 0x02, 0x3E, 0x04, 0x00, 0xB4 };//adres dallas
int temperature1, temperature2, temperature3, temperature4, temperature5, temperature6;
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
SimpleTimer timer1;
// temperature1 V12
// temperature2 V13
// temperature3 V14
// temperature1 V19
// temperature2 V20
// temperature3 V21
WidgetLCD lcd(V15);
if (isPressed) {
led6.on();
lcd.print(1, 0, "BRANA OTVORENA");
Blynk.email("xxx@gmail.com", "BRANA OTVORENA!", "Brana je otvorena.");
led6.off();
lcd.print(1, 0, "BRANA ZATVORENA");
if (isPressed) {
led7.on();
lcd.print(1, 1, "GARAZ OTVORENA");
Blynk.email("xxx@gmail.com", "GARAZ OTVORENA!", "Garaz je otvorena.");
led7.off();
lcd.print(1, 1, "GARAZ ZATVORENA");
BLYNK_CONNECTED() {
BLYNK_WRITE(V1)//tlacitko ide 1sekundu nezalezi na dlzke zatlacenia
if (param.asInt()) {
led1.on();
led1.off();
BLYNK_WRITE(V2)//tlacitko ide 1sekundu nezalezi na dlzke zatlacenia
led2.on();
led2.off();
BLYNK_WRITE(V3) {
relaystate3 = param.asInt();
if (digitalRead(relay3) == HIGH) {
Blynk.virtualWrite(V17, "SVETLO ON");
led3.on();
else {
Blynk.virtualWrite(V17, "SVETLO OFF");
led3.off();
BLYNK_WRITE(V4) {
relaystate4 = param.asInt();
if (digitalRead(relay4) == HIGH) {
Blynk.virtualWrite(V18, "SVETLO1 ON");
led4.on();
else {
Blynk.virtualWrite(V18, "SVETLO1 OFF");
led4.off();
if (digitalRead(button1) == HIGH) {
led1.off();
led1.on();
if (digitalRead(button2) == HIGH) {
led2.off();
led2.on();
led3.on();
else {
Blynk.virtualWrite(V17, "SVETLO1 OFF");
led3.off();
buttonstate3 = LOW;
led4.on();
else {
led4.off();
buttonstate4 = LOW;
void ledonline()
led5.off();
led5.on();
void sendSensor4() {
temperature4 = sensors.getTempC(tempSensor4);
Blynk.virtualWrite(V19, temperature4);
void sendSensor5() {
temperature5 = sensors.getTempC(tempSensor5);
Blynk.virtualWrite(V20, temperature5);
void sendSensor6() {
temperature6 = sensors.getTempC(tempSensor6);
Blynk.virtualWrite(V21, temperature6);
// Blynk.email("xxx@gmail.com", "online", "wemos d1 mini je online.");
sensors.begin();
sensors.setResolution(tempSensor4, 10);
sensors.setResolution(tempSensor5, 10);
sensors.setResolution(tempSensor6, 10);
timer1.setInterval(5000L, sendSensor4);
timer1.setInterval(4800L, sendSensor5);
timer1.setInterval(4500L, sendSensor6);
timer1.run();
Hello, thanks for the code and it works verry good. I wonder if it is possible to burn an external LED as soon as the magnetic switches (GPIO5 and 4) start working and as LED (V10 and V11) light up
