Hi! Hope you’re having an awesome day.
I’ve been try to make requests to the REST API you guys have running on Blynk-cloud.com, I can use the isHardwareConnected and isAppConnected endpoints, but if i try to read or update a PIN value it simply won’t return a reply.
I feel like i’m doing something wrong, I’ve been looking for a solution for the past 6 hours with no answer in sight. I might be overthinking (which i do a lot), but I feel it’s something else.
Sorry for jumping on this thread, but I have a somewhat related problem.
For the past few hours, I have been trying to use the Aviary interface to change the auth_token on-the-spot to test out the API, without doing any coding first. But I keep getting error 404, saying I have an invalid token.
But I know my token is valid, as it is working in my Python file and I managed to get a Button widget value with it.
Read Dmitry’s post that the API is not yet deployed to Blynk Cloud, is that the reason why I keep getting the error?
What is the interim API call we should make before the latest API is released to Blynk Cloud then? When will it be released? Thank you!
