How to display local IP address in lcd widget?
I would like to output the local IP address of my device to the lcd with a WidgetLCD print but it returns an unexpected 10 digit number with no “.” ie:
void updateLCD() { IPAddress strWiFiIP = WiFi.localIP(); lcd.clear(); lcd.print(0, 0, "IP address:"); lcd.print(0, 1, strWiFiIP); }
expected output: 192.168.1.239
output: 4009863360
What is the correct way to achieve this?
This works, just tried it:
lcd.print(0, 1, WiFi.localIP().toString());
Handly little IP to long and long to IP converter at http://www.smartconversion.com/unit_conversion/IP_Address_Converter.aspx
4009863360 shows 239.1.168.192 (192.168.1.239 in reverse).
So would it be correct to say that WiFi.localIP() returns the IP in “long decimal” format and that print.terminal() and print.serial() seem to automatically convert but lcd.print() needs a little help from toString() ?
Thanks for your help by the way. My IP address is now displaying correctly. This method is far neater than splitting the ip address into a 2 dimensional array like what is described elsewhere.
Although it’s not necessary to achieve the goal of displaying the IP address on the display I have a related question about storing the IP address in a 1 dimensional array:
I would have expected this code to work given Costas reply:
char localIPaddr[16]; void setup() { localIPaddr[] = WiFi.localIP().toString(); } updateLCD() { lcd.print(0, 1, localIPaddr); }
But it gives a compile error. What is the best way to store the local IP address in a character array ?
I think the format is actually IPAddress which Serial and terminal are ok with but LCD will only accept Strings.
I think the IPAddress value is actually an array of chars, but I’m not sure.
@grieve2774 IPAddress is a unique data format made up of four octets in an array. Serial Monitor for the following sketch:
IP address in IPAddress format: 192.168.10.236
IP address in unsigned long format: 3960121536 [octet values are transposed]
long back to IP, for sanity check: 192.168.10.236
Octet by octet: 192.168.10.236
Sketch that shows you the array format:
 // IPAddress.ino prepared by Costas 22/8/16.
 // The ESP IPAddress data type used toCharArray() for a few hours, 21st Aug 2015.
 // It was then changed to use toString() and the format is a 4 byte array in octets.
 // There are also some special print functions fr IPAddress data type.
 // Converter http://www.smartconversion.com/unit_conversion/IP_Address_Converter.aspx
 // Converter http://www.ipaddressguide.com/ip
 // see https://github.com/esp8266/Arduino/blob/master/cores/esp8266/IPAddress.cpp
 // see https://github.com/esp8266/Arduino/blob/master/cores/esp8266/IPAddress.h
const char* ssid     = "xxxxxxxxxxxxx";
const char* password = "xxxxxxxxxxxxx";
  Serial.println();
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println();
  IPAddress myip = WiFi.localIP();
  unsigned long myiplong = WiFi.localIP();
  Serial.print("IP address in IPAddress format: ");
  Serial.println(myip);
  Serial.print("IP address in unsigned long format: ");
  Serial.print(myiplong);
  Serial.println(" [octet values are transposed]");
  IPAddress reversedIP = myiplong;
  Serial.print("long back to IP, for sanity check: ");
  Serial.println(reversedIP);
  Serial.print("Octet by octet: ");
  Serial.print(myip[0]);
  Serial.print(".");
  Serial.print(myip[1]);
  Serial.print(".");
  Serial.print(myip[2]);
  Serial.print(".");
  Serial.println(myip[3]);
  delay(1);
@Costas any idea about how to get it work ip address on lcd widget?
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
extern "C" {
  uint16 readvdd33(void);
WidgetLCD lcd(V10);
long rssi;
int Led1=D4;
int Led2=D5;
void myTimerEvent()
  Blynk.virtualWrite(V11, millis() / 60000);                           // Uptime
  Blynk.virtualWrite(V12,readvdd33());                                // Voltage
  unsigned long maxMillis=millis() + 8000;
  while ((Blynk.connect() == false) && ( millis() <= maxMillis)) {
  Blynk.notify("NodeMCU Started!");
  timer.setInterval(60000L, myTimerEvent);
  rssi=WiFi.RSSI();
  myip=WiFi.localIP();
BLYNK_WRITE(V4)                                                 // Wifi strength
 int pinData = param.asInt();
 if(pinData==1)
   lcd.clear();
   lcd.print(0 ,0,"Wifi Strength");
   lcd.print(0 ,1,rssi);
 }else
   lcd.clear();
BLYNK_WRITE(V5)                                                    // IP Address
 if(pinData==1)
   lcd.clear();
   lcd.print(0 ,0,"IP ADDRESS:");
   lcd.print(0 ,1,myip);
 }else
   lcd.clear();
@elanozturk if you don’t want to work with the data type IPAddress, which is a bit cumbersome, try changing:
to:
lcd.print(0, 1, WiFi.localIP());
Your sketch compiles with this change but I haven’t connected it up to a virtual LCD. We generally use Terminal and terminal.println(WiFi.localIP()) works fine so it should be OK for the LCD.
Thank you @Costas tried but no luck,i’m getting same value on lcd widget,should i use terminal widget instead of?
@elanozturk no you don’t need to switch to Terminal.
Just setting up a virtual LCD and then I’ll get back to you.
@elanozturk back to using IPAddress datatype the following works on my virtual LCD:
lcd.print(0, 1, myip[0]);
lcd.print(3, 1, “.”);
lcd.print(4, 1, myip[1]);
lcd.print(7, 1, “.”);
lcd.print(8, 1, myip[2]);
lcd.print(11, 1, “.”);
lcd.print(12, 1, myip[3]);
This works nicely if each octet is 3 digits long like 192.168.100.123 but leaves unsightly gaps for an IP address such as 10.10.10.1, which would display as 10 .10 .10 .1
Not a major issue but I’ll try to join the array into a single string that will skip the gaps.
This will look better on your LCD for all IP addresses:
   String fullip = String(myip[0]) + "." + myip[1] + "." + myip[2] + "." + myip[3];
   lcd.print(0, 1, fullip);
Just to add the correct structure for using the IP address is not in loop() as the IP doesn’t change after setup() so:
IPAddress myip; // declare the variable
myip = WiFi.localIP(); // in setup() after Blynk connection and nothing in loop for IP
Thank you @Costas ,i am trying to place codes to correct places in my sketch :slight_smile:
declaration of the variable goes after your libraries.
myip = … goes after the while statement in setup.
In V5:
String fullip = String(myip[0]) + “.” + myip[1] + “.” + myip[2] + “.” + myip[3];
Finally i succeed with your help,thank you @Costas very appreciated. :grinning: :+1:
This also works with Blynk virtual write to widgets.
Blynk.virtualWrite(V2, WiFi.localIP().toString());
I have a number of WeMos D1 mini devices around the house, I update them via OTA . . .I added a Labeled value widget to each project to display the local IP address - makes it easy to identify each device from the app rather than maintaining a list of IP addresses.
Thnx for your simple solution (I had the same formatting issues as OP)
cul
billd
