how to control esp8266 and led with physical and blynk app button. im using esp8266 which has only 2 gpio pins GPIO0 and GPIO2. i want to turn on and off from both button. please help me im new to blynk.
this code i found in community can i modify this code to do what i want?
char auth[] = "xxxxx"; //insert here your token generated by Blynk
int relay1 = 12;
int button1 = 13;
int relayVButton = 0;
boolean relayState = 1;
boolean buttonState = 0;
WidgetLED led1(11); //virtual led
Serial.begin(115200); // See the connection status in Serial Monitor
Blynk.begin(auth, "ssid", "password"); //insert here your SSID and password
buttonState = digitalRead (button1);
if (buttonState > 0){
relayState = !relayState;
digitalWrite(relay1, relayState);
delay(500);
pinMode(relay1, OUTPUT);
pinMode(button1,INPUT);
BLYNK_WRITE(V5)
// Get the state of the VButton
relayVButton = param.asInt();
if (buttonState > 0 || relayVButton > 0){
delay(500);
//----------------button virtual led---------------
byte inp = digitalRead(relay1);
if (inp == HIGH)
led1.on();
led1.off();
1 Reply
