GrovePi - A way to integrate sensors easily with the Raspberry Pi. This is sort of an IOT starter kit, where the sensors can plug in with cables and different ports.
{Disclaimer I am the founder of Dexter Industries! }
I see that the UDOO Neo is on the Roadmap any chance you will add the UDOO Quad?
Please add the LaunchPad CC3200 from Texas Instruments and virtually all the LaunchPads with the CC3100 BoosterPack
See my contribution and my project Blynk Weather and Security Station
We believe that itās working! And we really appreciate your contribution!
However, we need to test it on our end. Thatās the only way for now. We just want to deliver highest quality, please understand us.
The only option is that at least a few other users confirm that itās working perfectly.
Anyway, hardware is on the way to @vshymanskyy. So it should be ready early September.
Thank you for your answer. I understand your policy about quality.
Actually, Iām using the very same method for embedXcode, a plug-in for embedded computing on Xcode. I test every single board before releasing support for it.
Good luck!
I am thinking Blynk should already be compatible with this project? https://www.kickstarter.com/projects/sweetpeas/nodeit-the-worlds-smallest-and-extendable-iot-syst/description
How about GSM/GPRS?
Dan
how about PLC language ? Like codesys from 3S.
My home automation is based on this with eaton PLC.
How do you connect your PLC to the internet?
Itās this kind of PLC/HMI : Touchscreen / Ethernet / CAN bus / RS232 Port.
SoftPLC is running under windows ce 5.0.
The just released Blynk app for Android now supports the LaunchPad CC3200.
Congratulations!
Please add the Adafruit Hazzah
Just use Esp8266 for this one
is this supported ā¦STM32 ARM Cortex-M3 Leaflabs Leaf Maple Mini ?
Nope. Maybe weāll get to it at some pointā¦ Added to āUnder Considerationā. Thanks!
ok, iāll wait until doneā¦
thanks for respond
What about the Adafruit Fona breakout boards?
Not supported yet. Maybe some time in the futureā¦
Hi, you have listed Electric Imp as the roadmap, I wonder how close they are. To me this is the list of wifi connected platforms that pretty much ready for professional prototype, or even professional consumer products:
Many thanks.
may i suggest Pololu Maestro if possible, please?
thank you
m.
