The title says it all. Is there any reason that I am not seeing any GPS trigger widget, or any other sensor widget for that matter? I know there must be a simple solution, but I am not seeing documentation anywhere.
On iOS it is not implemented yet.
Thank you for the quick response! Is it expected to be released for iOS in the near future?
Some day - yes. But not innearest future. As this is rarely used widget.
Hi, how are you? I’m using google translator.
Could you help me with tigger gps, as I did not understand how to configure the geographic point, which widget to use?
The gps tigger or map.
Could you please make a video tutorial or step by step photos of how to setup the tigger gps?
The gps trigger or map.
Could you please make a video tutorial or step by step photos of how to setup the trigger gps?
