Faster navigation between dashboards
I use multiple dashboards, and often get a little frustrated navigating between them.
First, there’s the random ordering. Instead of maintaining the same sequence in which I created them, my dashboards re-order themselves spontaneously. One day, my thermostat dashboard is to the left of my lighting dashboard, and a couple days later, they’ve moved 3 dashboards apart. The self re-ordering might make sense if it were done for a logical reason (e.g. arranging themselves from most used to least used), but that doesn’t seem to be the case.
Second, I wish there were a faster way to navigate between the dashboards. Currently, it’s a 3 step process. Click the switcher button, slide left or right to find the dashboard you want, and click to select it. Wouldn’t it be nice if you could cycle through dashboards by just sliding right or left in a blank part of the dashboard, or even on the header bar?
Hello. Swipe is already in todo list. Do you have ios/android?
@ Dmitry I’m on iOS.
This is probably a bug, re-ordering shouldn’t happen. Thanks for the report!
