ESP8266 with Relay onboard
Hi all.
Found this. I think its really interesting for its compact size.
Interesting but a bit dated now since it looks like its using the ESP-01 which won’t allow Over The Air updates due to flash limits.
See also here, that is cheaper and full esp8266…
http://www.electrodragon.com/product/wifi-iot-relay-board-vdc-based-esp8266/
That’s more like it!
I like the price. -those relays are limited to >125vac max and a maximum of 3amps, but are connectorized to wimpy .1" header posts. I designed a “quarter” pc board (1.2" X 1.8") that is line powered (100vac-250vac, 50 or 60hz) at http://piwifio.com/WiFiSPST.html . It is using a 277vac/16amp relay and an Esp12-e for the WiFi. Because of the relay design, NO switched current runs through the PC board. The relay uses “Sta-Kon” connectors. The “pgm” header is also used for an on/off pushbutton.
