As promised, here’s the latest iteration, which now includes Amazon Echo voice control for a few commands (via IFTTT), and and color coding of some widgets to indicate whether it is in heating, cooling, or neutral modes.
* ThermoX v0.15 HVAC control for a "2-pipe" radiator system.
* Compares readings from a DHT11 temperature sensor with desired temperature
* from the Blynk application, and runs the fan unit as necessary to heat or
* cool. Hysteresis levels for both Summer and Winter are independently
* adjustable from 2 to 6 degrees. The temperature sensor readings can be
* offset up or down by up to 5 degrees. All settings are saved to EEPROM, and
* automatically reloaded on startup.
* "Home" setting is triggered by IFTTT iOS location channel, and results in an
* action on the Maker channel. The Maker channel parameters are as follows:
* URL: http://blynk-cloud.com:8080/YOUR_TOKEN/pin/V31
* Method: PUT
* Content Type: application/json
* Body: ["1"]
* "Away" mode requires an identical IFTTT recipe, but with
* Body: ["0"]
* Added color coding (red/blue) for heating and cooling modes to dashboard widgets.
* Added IFTTT / Amazon Echo integration for operating with voice commands. Uses
* the IFTTT Maker Channel in the same way as above, but with an Amazon Alexa voice
* trigger. To manually run the fan, use the following Maker Channel parameters:
* URL: http://blynk-cloud.com:8080/YOUR_TOKEN/pin/V6
* Method: PUT
* Body: ["1"]
* Make identical recipes (now called applets) for Temperature Up and Temperature
* Down, substituting Body values of ["2"] and ["3"], repsectively.
* Added a press-and-hold requirement to enter the settings menu, as well as
* a Menu timeout and reset after a period of inactivity.
* Added manual overrides to force system run or halt, independent of other factors.
* Added a diagnostic mode that outputs temperature readings to the SETTINGS widget.
* Extended lower limit of temperature correction to -10 degrees.
* Fixed arithmetic bug that was causing Blynk to show ESP as "offline"
* WiFi connection is now simplified with Tapzu's WiFiManager. Wifi automatically
* reconnects to last working credentials. If the last SSID is unavailable, it
* creates an access point ("BlynkAutoConnect"). Connect any wifi device to the
* access point, and a captive portal pop up to receive new wifi credentials.
* The hardware is minimal: an ESP-01, a single relay on GPIO 0, and a DHT11
* temperature sensor on GPIO 2.
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include "DHT.h"
#include <EEPROM.h>
#define UpdateFrequency 10000 //How often a new temperature will be read
#define MenuTimeOut 7000 //Menu timeout from inactivity
#define LongPress 650 //How long SETTINGS button needs to be pressed to enter menu
#define RelayPin 2
#define BLYNK_BLUE "#04C0F8"
#define BLYNK_RED "#D3435C"
#define BLYNK_WHITE "#FFFFFF"
DHT dht(0,DHT11); //Initialize the sensor. Use pin 0. Sensor type is DHT11.
// Timer for temperature updates
//WiFi and Blynk connection variables
char auth[] = "TOKEN"; // Blynk token "YourAuthToken"
//Thermostat variables
int TempDes = 70; //Desired temperature setting
int PreviousTempDes;
int TempAct = 70; //Actual temperature, as measured by the DHT11 sensor
int BadRead = 0; //Counts consecutive failed readings of the DHT11 sensor
float LastRead = 70;
// Preference variables
int Hysteresis_W = 2; //Summer and Winter hysteresis levels
int Hysteresis_S = 2;
int TempCorrection = 0; //Used to adjust readings, if the sensor needs calibration
// Current condition variables
boolean Winter = true;
boolean Home = true;
boolean ManualRun = false; // used to run fan, overriding thermostat algorithm
boolean ManualStop = false; // used to stop fan, overriding thermostat algorithm
boolean DigitalTemp = false; // used to show temperature in SETTINGS value widget
int MenuItem = 0; // Settings menu selection variable
long buttonRelease; // time button was released
long buttonPress; // time button was last pressed
boolean ButtonDown = false; // Settings button state (pressed = true)
boolean FanState = 0; // is the fan on or off?
String Response = ""; // Text output to SETTINGS value widget
String myHostname = "ThermoX";
// Create an access point if no wifi credentials are stored
WiFi.hostname(myHostname);
WiFiManager wifi;
wifi.autoConnect("ThermoX");
Blynk.config(auth);
dht.begin(); //Start temperature sensor
delay(1500);
//Initialize the fan relay. Mine is "off" when the relay is set HIGH.
pinMode(RelayPin,OUTPUT);
digitalWrite(RelayPin,HIGH);
//Load any saved settings from the EEPROM
EEPROM.begin(20);
Serial.println(F("STARTUP : LOADING SETTINGS FROM MEMORY"));
Serial.println(F(""));
GetPresets();
PreviousTempDes = TempDes;
MenuReset();
timer.setInterval(UpdateFrequency, TempUpdate); // Update temp reading and relay state
timer.setInterval(200, ButtonCheck);
// Main loop
// Checks for long press condition on SETTINGS button
void ButtonCheck(){
if (ButtonDown){
// Enter or exit the SETTINGS menu, if it was a long press
if (millis() - buttonPress > LongPress){
if (MenuItem == 0){
NextMenuItem(); // Enter the SETTINGS menu
else MenuReset(); // Exit the SETTINGS menu
ButtonDown = false; // Prevent repeat triggering
// This is the decision algorithm for turning the HVAC on and off
void TempUpdate (){
OtherUpdates(); //Refeshes dashboard information
float ReadF = dht.readTemperature(true); //Get a new reading from the temp sensor
if (isnan(ReadF)) {
Serial.println(F("Failed to read from DHT sensor!"));
BadRead++;
return;
//To compensate for some instability in the DHT11, the corrected temperature is
//averaged with previous read, and any change is limited to 1 degree at a time.
else {
int TempAvg = int((ReadF + LastRead + (2 * TempCorrection))/2);
if (TempAvg > TempAct){
TempAct += 1;
if (TempAvg < TempAct){
TempAct -= 1;
LastRead = ReadF;
BadRead = 0; // Reset counter for failed sensor reads
Blynk.virtualWrite(V0,TempAct); //Report the corrected temperature in app
Serial.print("Actual temperature: ");
Serial.println(TempAct);
if (DigitalTemp){ //Report the temperature to the SETTINGS widget
Blynk.virtualWrite(V10,"-----------------------");
delay(50);
Blynk.virtualWrite(V10,String("TEMPERATURE: ") + TempAct);
// Decision algorithm for running HVAC
if (!ManualRun && !ManualStop){ // Make sure it's not in one of the manual modes
// If I'm home, run the algorithm
if (Home){
if (Winter){
//If I'm home, it's Winter, and the temp is too low, turn the relay ON
if (TempAct < TempDes){
FanState = 1;
Fan();
//Turn it off when the space is heated to the desired temp + a few degrees
else if ((TempAct >= (TempDes + Hysteresis_W)) && FanState) {
FanState = 0;
Fan();
else if (!Winter){
//If I'm home, it's Summer, and the temp is too high, turn the relay ON
if (TempAct > TempDes){
FanState = 1;
Fan();
//Turn it off when the space is cooled to the desired temp - a few degrees
else if ((TempAct <= (TempDes - Hysteresis_S)) && FanState){
FanState = 0;
Fan();
// If I'm not home, turn the relay OFF
else {
FanState = 0;
Fan();
//Match temp gauge to slider in Blynk app
BLYNK_WRITE(V3){
TempDes = param.asInt();
Blynk.virtualWrite(V1,TempDes);
//Get location (home or away) from the IFTTT iOS location and Maker channels
BLYNK_WRITE(V31)
Home = param.asInt();
if (Home){ //Turn the HOME LED widget on or off
Blynk.virtualWrite(V29,1023);
else Blynk.virtualWrite(V29,0);
// Dashboard SETTINGS button. Press-and-hold to enter menu. Short press for next item.
BLYNK_WRITE(V4) {
// Check for a button press
ButtonDown = param.asInt();
if (ButtonDown){
buttonPress = millis();
// check for button release
else {
buttonRelease = millis();
if (buttonRelease - buttonPress < LongPress){ // It was a short press.
if (MenuItem == 0){
MenuReset(); // Remind user to hold 2 seconds to enter menu
else NextMenuItem(); // Advance to next menu item
//Cycles through the Settings Menu in the Labeled Value widget
void NextMenuItem(){
MenuItem += 1;
if (MenuItem > 9){
MenuItem = 1;
switch(MenuItem){
case 1:
if (ManualRun){
Response = "END MANUAL RUN?";
else{
Response = "RUN MANUALLY?";
break;
case 2:
if (ManualStop){
Response = "END SYSTEM HALT?";
else{
Response = "HALT SYSTEM?";
break;
case 3:
if (Home){
Response = "LOCATION: HOME";
else Response = "LOCATION: AWAY";
break;
case 4:
if (Winter){
Response = "MODE : WINTER";
else Response = "MODE : SUMMER";
break;
case 5:
if (Winter){
Response = "HYSTERESIS: ";
Response += Hysteresis_W;
Response += " DEG";
else{
Response += Hysteresis_S;
Response += " DEG";
break;
case 6:
Response = "TEMP CORRECTION: ";
Response += TempCorrection;
Response += " DEGREES";
break;
case 7:
Response = "DIAGNOSTIC MODE?";
break;
case 8:
Response = "CLEAR WIFI SETTINGS?";
break;
case 9:
Response = "RESET ALL DEFAULTS?";
break;
Blynk.virtualWrite(V10,Response);
//Dashboard MODIFY button. Executes change of selected menu item
BLYNK_WRITE(V5){
buttonRelease = millis(); //Resets menu timeout for inactivity
if ((MenuItem > 0) && (param.asInt())){
switch(MenuItem){
//Forced on
case 1:
if (ManualRun){
ManualRun = false;
else{
ManualRun = true;
ManualStop = false;
FanState = 1;
Fan();
Response = "MANUAL RUN: ON";
break;
//Forced halt
case 2:
if (ManualStop){
ManualStop = false;
else {
ManualStop = true;
ManualRun = false;
FanState = 0;
Fan();
Response = "SYSTEM HALTED";
break;
//Change location manually
case 3:
if (Home){
Home = false;
Response = "LOCATION : AWAY";
else {
Home = true;
Response = "LOCATION : HOME";
break;
//Change season
case 4:
if (Winter){
Winter = false;
EEPROM.write(4,0);
EEPROM.commit();
else {
Winter = true;
EEPROM.write(4,1);
EEPROM.commit();
break;
//Change hysteresis level of currently selected season
case 5:
if (Winter){
Hysteresis_W += 1;
if (Hysteresis_W > 6){
Hysteresis_W = 1;
EEPROM.write(1,(Hysteresis_W));
EEPROM.commit();
Response = "WINTER HYSTERESIS: ";
Response += " DEG";
else{
Hysteresis_S += 1;
if (Hysteresis_S > 6){
Hysteresis_S = 1;
EEPROM.write(2,(Hysteresis_S));
EEPROM.commit();
Response = "SUMMER HYSTERESIS: ";
Response += " DEG";
break;
// Correct faulty DHT11 readings
case 6:
TempCorrection +=1;
if (TempCorrection > 5){
TempCorrection = -10;
EEPROM.write(0,(TempCorrection + 10));
EEPROM.commit();
Response = "TEMPERATURE CORRECTION: ";
Response += " DEG";
break;
// Send temperature readings to the SETTINGS value widget
case 7:
if (!DigitalTemp){
Response = "ENTERING DIAGNOSTIC MODE";
DigitalTemp = true;
MenuItem = 0; //Prevents menu reset
delay(400);
else {
Response = ("DIAGNOSTIC MODE?");
break;
//Clear stored SSID and password
case 8:
Response = "ERASING WIFI CREDENTIALS";
WiFi.begin("FakeSSID","FakePW"); //replace current WiFi credentials with fake ones
ESP.restart();
break;
//Clear current temperature settings
case 9:
Response = "All settings reset to default!";
Winter = true;
Hysteresis_W = 2;
Hysteresis_S = 2;
break;
Blynk.virtualWrite(V10, Response);
// Receives commands from IFTTT Maker Channel via the Amazon Echo.
// Pin V6 is not actually associated with a Blynk dashboard widget.
BLYNK_WRITE(V6){
int AlexaCommand = param.asInt();
switch(AlexaCommand){
// Turn manual running on / off
case 1:
Serial.println("Manual run");
if (ManualRun){
ManualRun = false;
else{
ManualRun = true;
ManualStop = false;
FanState = 1;
Fan();
break;
// Increase desired temperature by 2 degrees
case 2:
Serial.println("Raise temperature 2 degrees.");
TempDes += 2;
break;
// Decrease desired temperature by 2 degrees
case 3:
Serial.println("Lower temperature 2 degrees.");
TempDes -= 2;
break;
// Turn the HVAC on or off
void Fan(){
// Set the proper color for the Desired Temp gauge and ON/OFF LED
//(red = heating, blue = cooling, white gauge or LED off = within desired range)
if (Winter && FanState){
Blynk.setProperty(V1, "color", BLYNK_RED);
Blynk.setProperty(V7, "color", BLYNK_RED);
else if (!Winter && FanState){
Blynk.setProperty(V1, "color", BLYNK_BLUE);
Blynk.setProperty(V7, "color", BLYNK_BLUE);
else{
Blynk.setProperty(V1, "color", BLYNK_WHITE);
digitalWrite(RelayPin,!FanState); // Relay turns fan on with LOW input, off with HIGH
Blynk.virtualWrite(V7,FanState * 1023);// fan "ON" LED on dashboard
Serial.print(F("Fan state: "));
Serial.println(FanState);
// Reset the Menu at startup or after timing out from inactivity
void MenuReset(){
MenuItem = 0;
Blynk.virtualWrite(V10, String("-----------------------"));
delay(50);
Blynk.virtualWrite(V10, String("HOLD 2 SEC TO ENTER/EXIT MENU"));
// Updates dashboard information on the Blynk app
void OtherUpdates(){
Blynk.virtualWrite(V29,Home * 1023); // Update "home" LED on dashboard
Blynk.virtualWrite(V1,TempDes); //Update desired temp on the dashboard
//Reset the Settings Menu if there's been no activity for a while
if (MenuItem > 0 && (millis() - buttonRelease > MenuTimeOut)){
MenuReset();
// Notify when the temperature sensor fails repeatedly, and turn off the fan.
if (BadRead > 10){
Blynk.virtualWrite(V10, String("<<< SENSOR MALFUNCTION >>>"));
BadRead = 0;
if (!ManualRun){ //Manual mode supersedes a malfunction condition
FanState = 0;
Fan();
if (TempDes != PreviousTempDes){ //update the EEPROM if desired temperature had changed.
EEPROM.write(3,TempDes);
EEPROM.commit();
Serial.print(F("New desired temperature saved: "));
Serial.println(TempDes);
//Retrieves saved values from EEPROM
void GetPresets(){
TempCorrection = EEPROM.read(0);
if ((TempCorrection < 0) || (TempCorrection > 15)){
TempCorrection = 0;
Serial.println(F("No saved temperature correction."));
else{
TempCorrection -= 10; // 10 was added at EEPROM save to account for negative values
Serial.print(F("Temperature correction: "));
Serial.print(TempCorrection);
Serial.println(F(" degrees."));
Winter = EEPROM.read(4);
Hysteresis_W = EEPROM.read(1);
Hysteresis_S = EEPROM.read(2);
if ((Hysteresis_W < 2) || (Hysteresis_W > 6)){
Hysteresis_W = 2;
if ((Hysteresis_S < 2) || (Hysteresis_S > 6)){
Hysteresis_S = 2;
if (Winter){
Serial.println(F("Season setting: Winter / heating"));
Serial.print(F("Winter hysteresis: "));
Serial.print(Hysteresis_W);
else {
Serial.println(F("Season setting: Summer / cooling"));
Serial.print(F("Summer hysteresis: "));
Serial.print(Hysteresis_S);
TempDes = EEPROM.read(3);
if ((TempDes < 50) || (TempDes > 80)){
TempDes = 70;
Serial.println(F("No saved temperature setting."));
else {
Serial.print(F("Desired temperature: "));
Serial.print(TempDes);
Serial.println("");
