Hi I am getting some errors after downloading 3.10 and then updating the delta from github.
Any suggestions?
In file included from C:\Program Files (x86)\Arduino\hardware\espressif\esp32\cores\esp32/Arduino.h:52:0,
from sketch\ESP32.ino.cpp:1:
Blynk/BlynkDebug.h: In function 'void blynk_dbg_print(const char*, ...)':
C:\Program Files (x86)\Arduino\hardware\espressif\esp32\cores\esp32/WString.h:39:53: error: 'PSTR' was not declared in this scope
#define F(string_literal) (FPSTR(PSTR(string_literal)))
C:\Program Files (x86)\Arduino\hardware\espressif\esp32\cores\esp32/WString.h:38:76: note: in definition of macro 'FPSTR'
#define FPSTR(pstr_pointer) (reinterpret_cast<const __FlashStringHelper *>(pstr_pointer))
Blynk\src/Blynk/BlynkDebug.h:170:31: note: in expansion of macro 'F'
BLYNK_PRINT.print(F("] "));
In file included from Blynk\src/BlynkSimpleEsp32.h:21:0,
from espBlynk\ESP32\ESP32.ino:31:
Blynk\src/BlynkApiArduino.h: In member function 'void BlynkApi<Proto>::processCmd(const void*, size_t)':
Blynk\src/BlynkApiArduino.h:161:31: error: there are no arguments to 'analogRead' that depend on a template parameter, so a declaration of 'analogRead' must be available [-fpermissive]
rsp.add(analogRead(pin));
Blynk\src/BlynkApiArduino.h:161:31: note: (if you use '-fpermissive', G++ will accept your code, but allowing the use of an undeclared name is deprecated)
Blynk\src/BlynkApiArduino.h:172:36: error: there are no arguments to 'analogWrite' that depend on a template parameter, so a declaration of 'analogWrite' must be available [-fpermissive]
analogWrite(pin, it.asInt());
Blynk\src/BlynkApiArduino.h: In instantiation of 'void BlynkApi<Proto>::processCmd(const void*, size_t) [with Proto = BlynkProtocol<BlynkArduinoClientGen<Client> >; size_t = unsigned int]':
Blynk\src/Blynk/BlynkProtocol.h:299:9: required from 'bool BlynkProtocol<Transp>::processInput() [with Transp = BlynkArduinoClientGen<Client>]'
Blynk\src/Blynk/BlynkProtocol.h:127:31: required from 'bool BlynkProtocol<Transp>::run(bool) [with Transp = BlynkArduinoClientGen<Client>]'
espBlynk\ESP32\ESP32.ino:50:13: required from here
Blynk\src/BlynkApiArduino.h:161:31: error: 'analogRead' was not declared in this scope
Blynk\src/BlynkApiArduino.h:172:36: error: 'analogWrite' was not declared in this scope
This was fresh setup for Arduino, i did a library install of 3.10 via Ardunio and also a git clone outside of that. I compared both dir and moved the missing files over. I did have to remove the standard wifi library as it complained about dual wifi.h for example.
I don’t have a lot of time invested in this Arduino setup. I could remove it and redo it from scratch if you think there is any benefit to it.
So programming the esp32 dev-c from adafruit can be done with arduino ide? And using the wemos d1 r2 to connect it with my computer as serial converter? (I don’t have a 3,3v serial ftdi)
Yes if you follow the instructions on the esp32.com forums or github repo. The esp32-dev-c has an on board usb to serial converter. I happen to also use a Particle Programmer board as well as I was also experimenting with jtag. .
can somebody please help, how to use blynk library with sparkfun esp32 thing?
i see that i can choose “esp32 dev board” in hardware list in the blynk app. but apparently there’s no sketch in the examples folder for esp32 in the arduino ide…
i would like to use this board with ble connection to android + blynk app. anybody has any experience with this setup?
thanks!
