Hi friends. can anyone help me why ESP32 cannot auto connect to wifi network ? is problem with void loop ? or … ?
my sketch:
#include <HardwareSerial.h>
#include <TinyGPS++.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
TinyGPSPlus gps; // The TinyGPS++ object
HardwareSerial ss(1);
char auth[] = "8b7e5fc4e68d43d9862145bbbcf0c136";
char ssid[] = "MikroTik Home";
char pass[] = "12345678";
char server[] = "10.5.51.3";
//unsigned int move_index;
unsigned int move_index = 1;
bool simulation = false;
bool IranHack = false;
WidgetMap myMap(V15);
Serial.println();
ss.begin(9600, SERIAL_8N1, 16, 17);
Blynk.begin(auth, ssid, pass, server, 8080);
timer.setInterval(5000L, checkGPS);
timer.setInterval(2000L, check);
void checkGPS(){
if (gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
Blynk.virtualWrite(V18, "GPS ERROR");
Blynk.virtualWrite(V16, "--------");
Blynk.virtualWrite(V17, "--------");
void displayInfo()
if (gps.location.isValid() || simulation == true || IranHack == true)
Blynk.virtualWrite(V18, "GPS OK");
float latitude = (gps.location.lat());
float longitude = (gps.location.lng());
if(latitude == 0 && longitude == 0 )
Blynk.virtualWrite(V18, "0,0");
Serial.print("LAT: ");
Serial.println(latitude, 6);
Serial.print("LONG: ");
Serial.println(longitude, 6);
Blynk.virtualWrite(V16, String(latitude, 6));
Blynk.virtualWrite(V17, String(longitude, 6));
myMap.location(move_index, latitude, longitude, "ESP32Location");
Serial.print(F("INVALID"));
Blynk.virtualWrite(V18, "GPS INVALID");
Serial.println();
void check()
if(simulation == true || IranHack == true)
displayInfo();
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayInfo();
thanks
@ErfanDL Can you paste the serial monitor output?
Try blynk.config instead of blynk.begin and see if it connects.
Edit: It would be better to manage the connections in sequence. Wifi first, see if it connects and then blynk connect. Use of BLYNK_CONNECTED() will also allow you to print some info or turn on/off LEDs as indicators.
thanks for reply
here SM output
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:956
load:0x40078000,len:0
load:0x40078000,len:13256
entry 0x40078a90
[18] Connecting to MikroTik Home
[3592] Connected to WiFi
[3592] IP: 10.5.50.15
[3592]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.1 on ESP32
[3597] Connecting to 10.5.51.3:8080
[3636] Ready (ping: 15ms).
LAT: 32.xx
LONG: 51.xx
LAT: 32.xx
LONG: 51.xx
[8637] Connecting to 10.5.51.3:8080
@ErfanDL You could do a timed routine to check wifi connection and reconnect or have a set of set of statements in loop() to check for wifi or blynk connections. Ideally, blynk.run() should re-establish the blynk connection which in turn will re-establish the wifi connection. It works like that for me.
thanks. is any example for blynk.config ?
Then just look at one of the constructors in BlynkEthernet.h:
void begin( const char* auth,
const char* domain = BLYNK_DEFAULT_DOMAIN,
uint16_t port = BLYNK_DEFAULT_PORT,
const byte mac[] = NULL)
BLYNK_LOG1(BLYNK_F("Getting IP..."));
if (!Ethernet.begin(SelectMacAddress(auth, mac))) {
BLYNK_FATAL(BLYNK_F("DHCP Failed!"));
// give the Ethernet shield a second to initialize:
BlynkDe…
https://community.blynk.cc/search?q=Auto%20reconnect
Gunner
April 9, 2018, 9:29pm
8
And this here is for ESP8266, but only a few library changes needed for ESP32
#9 Basic “Keeps running without WiFi or Blynk Server connection, but reconnects as soon as they are available” sketch
Simply does what the title says… Flashes the built in LED and sends UpTime data to both App and Serial monitor to show operation either way. Also has a lot of serial print commands to show general operation for troubleshooting… Remove them when you are comfortable that everything works for you.
http://docs.blynk.cc/#blynk-firmware-connection-management
#define BLYNK_PRINT Se…
Try not using a space in your SSID. That might help…
Emilio
April 10, 2018, 9:43am
10
Is the server’s IP correct?
Gunner
April 10, 2018, 9:51am
11
That would be the OPs Local Server… and it seems correct on initial boot
