I have my local server running I am trying to edit the raspberry client script to look for my local server can some one please help. I am learning as I go I am currently looking in /usr/lib/nde_modules/blynk-lib/bin/blynk-client.js
Should be something like this :
var blynk = new Blynk.Blynk(AUTH, options= {addr:"xxx.xxx.xxx.xxx"});
Ok so I need to replace
various blynk = new Blynk.Blynk (process.argv[2])…?
Is that correct.
yes
Thanks you thats what I thought you have been a great help!
/usr/lib/node_modules/blynk-library/bin/blynk-client.js:12
var blynk = new Blynk.Blynk(AUTH, options= {addr:“192.168.1.3”});
ReferenceError: AUTH is not defined
at Object. (/usr/lib/node_modules/blynk-library/bin/blynk-client.js:12:29)
at Module._compile (module.js:456:26)
at Object.Module._extensions…js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Function.Module.runMain (module.js:497:10)
at startup (node.js:119:16)
at node.js:906:3
??? sorry to be a bother…do i need to set a variable for AUTH?
This is what I have.
In your case it should be process.argv[2]
Thank You.
Ok Got the IP set now I need to change the port it is could you lead me in the right direction.
This is just a guess… heaven knows my RPi experience is shaky But perhaps use x.x.x.x:port ?
var blynk = new Blynk.Blynk(process.argv[2], options= {addr:“xxx.xxx.xxx.xxx”, port: xxxx});
working though SSL not authorized
I ment ...options = {addr:"xxx.xxx.xxx.xxx:xxxx});
But again, not sure if that will work in this context.
Gotcha may try it just so we know I am new to this so learning as I go.
it throws a syntax error
OK, try this
...options = {addr:"xxx.xxx.xxx.xxx", pppp});
