I have in my Blynk project app Two esp8266 working (one esp8266-01 and a Nodemcu), everyone is independient with his own power.
Today I watched that both devices goes ofline at exactly the same time (10:45 am) without any problem of wifi signal, internet or AC-DC power, so there is posible that Blynk cloud goes down at that time? O maybe there are some restrictions about how much tieme is devide connected to Blynk Cloud?
Then at the afternoon unplugged both devides and plug them again and every one goes online again (doesn´t supose that automatically should goes online when they are offline for some time)??
#include <Ultrasonic.h> // se incluye la librería ultrasónica
Ultrasonic ultrasonic(5,4); // (Trig PIN,Echo PIN)
#include "DHT.h"
#define DHTPIN 0 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE);
char auth[] = "8a9c8df766c84ed99380391f34d653ea";
void sendUptime()
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius
// Read temperature as Fahrenheit
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
return;
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(" Temperatura *C: " );
Serial.println(t);
Serial.print(" Humedad %: " );
Serial.println(h);
Serial.print("Sensacion termica *C: ");
Serial.println(hic);
Blynk.virtualWrite(V1, t);
Blynk.virtualWrite(V2, h);
Blynk.virtualWrite(V3,hic);
void setup() //---------------------------------------------------------------------- SETUP -------------------------------------------------------------
WiFi.mode(WIFI_STA);
int cnt = 0;
delay(500);
Serial.print(".");
if (cnt++ >= 10) {
WiFi.beginSmartConfig();
while (1) {
if (WiFi.smartConfigDone()) {
Serial.println("");
BLYNK_LOG("SmartConfig: Success");
break;
Serial.print("|");
WiFi.printDiag(Serial);
Blynk.config(auth);
//********************************************************************** AGREGADO PARA SYNC
while (Blynk.connect() == false) { }
Blynk.syncAll();
dht.begin(); // INICIAR SENSOR DE TEMPERATURA
timer.setInterval(5000, sendUptime); //1000=1s
void loop() // -------------------------------- LOOP -----------------------------------------------
//****************************************************************************************************** ULTRASONICO
Serial.print(ultrasonic.Ranging(CM)); // CM or INC
Serial.println(" cm" );
delay(100);
Blynk.virtualWrite(V5, ultrasonic.Ranging(CM));
delay(200);
Jamin
March 7, 2017, 9:40pm
3
Coding errors causing a flood and disconnection.
You cannot have Blynk.virtualWrite() in the loop(),. It must be behind a timer.
Study the PushData example provided by Blynk.
Also remove all delay()'s from your code and use timers instead.
Thanks Jamin, do you think is good now? Could you give an example about using timers instead of delays?
#include "DHT.h"
void sendUptime()
return;
Serial.print("Temperatura *C: " );
Serial.println(t);
Serial.print("Humedad %: " );
Serial.println(h);
float ult = ultrasonic.Ranging(CM);
Serial.print("Distancia en cm: " );
Serial.println(ult); // CM or INC
Blynk.virtualWrite(V5, ult);
int cnt = 0;
delay(500);
Serial.print(".");
if (cnt++ >= 10) {
while (1) {
Serial.println("");
break;
Serial.print("|");
Blynk.config(auth);
Blynk.syncAll();
delay(100);
delay(200);
Jamin
March 7, 2017, 10:19pm
5
This is the area you need to remove from the loop
delay(100);
delay(200);
YES, I commentedout that to remove it from compilation, thanks!
Jamin
March 7, 2017, 10:44pm
7
Okay its hard to see with all your massive line comments…
Well. Between you and Blynk Cloud many routers on its way. In case somewhere something goes down your connection will be dropped. So connection drops may happen. This is the normal situation for the internet. And if both hardware went offline at same time most probably this is the case.
