Hi to all.
Is anyone have example for Intel Edison. Because I was try so many sketches and libraries and didn’t work.
In DHTtester example i have the error:
C:\Users…\Documents\Arduino\libraries\DHT\DHT.cpp: In constructor ‘DHT::DHT(uint8_t, uint8_t, uint8_t)’:
C:\Users…\Documents\Arduino\libraries\DHT\DHT.cpp:18:46: error: ‘microsecondsToClockCycles’ was not declared in this scope
_maxcycles = microsecondsToClockCycles(1000); // 1 millisecond timeout for
Error compiling.
Did you use the Arduino IDE to add / remove libraries?
As per the docs, it’s a manual operation to install all the required libraries but as BlynkTimer was introduced into the main Blynk library from 0.4.7 it should work if you have this or newer.
@Costas On when you typing last reply I read through again your previous message and I figure it out I was having old Blynk library and now I delete old on and reinstall new one and compiled successfully. Thanks
When using DHT11 and DHT22 sensors it might be a good idea to use Arduinos libraries instead of Adafruits to minimize the reading time. Check out the last couple of post in this thread:
Here is my output and its look like they have some sudden spikes although it should be stable and also is there any way to change graph time stamps into 12Hrs formats…Currently its showing in 24Hrs format…
Currently I just keep it running as is and I will update here my graph after few hours of readings and also I just observe this ESP8266 some time loose connection and on my same network I hookup another ESP8266 along with its some GPIO connected with my Lights and fans and its working all time solid.
You need to precisely duplicate the solid system and then add SuperChart, anything else is meaningless because a single line of code that differs between solid and not solid could be the cause.
After one hour of deep test here is my output log and its looks like its not stable you can also observe the spikes in temperature graph at 7:49pm, 8:00pm, 8:25PM, 8:39PM 8:48PM and also on when I set graph in live mode bo0th values get flat at bottom.
@Costas For example if I change the time interval by increasing to update on server I think we can resolve this sudden spikes issue but how can I change the timer.run();
